Damaged wheel caps all round
Old Jan 22, 2005 | 01:18 PM
MARK_UK's Avatar
Exclamation Damaged wheel caps all round
Does anyone elses wheel caps look like this
see the white patches which look like cracking or lifting. It the same on all four caps and woundering if it's a faulty thing that could be replaced by the dealer under warrenty.
Old Jan 22, 2005 | 03:48 PM
Bob G's Avatar
Default Re: Damaged wheel caps all round
Mark:
When I get home, I'll check mine and let you know. I noticed the rest of the cap looks pitted, is that just dirt or is it buggered too?
Old Jan 22, 2005 | 03:54 PM
MARK_UK's Avatar
Originally Posted by Bob G
Mark:
The black stuff is that thing called Brake Dust
Old Jan 22, 2005 | 08:57 PM
Bob G's Avatar
Mark:
Just looked at all of my caps when I checked the tail pipes and they are mint. Is it at all possible that your car was in or splashed with ocean salt water? Rusty tail pipes, buggered caps....... Take a good look at anything metal under your car. I might be a little peronoid but I had an Oldsmobile many years ago that had rust in the weirdest places and I eventually found out that it had been under water. I'm not saying that it was under water as you would find rust under your dash etc. but a foot or so of ocean water would do it. Again it is a real long shot!!
I hope I'm wrong!
PS I know I spelled peronoid wrong!
Old Jan 22, 2005 | 10:13 PM
Dan Root's Avatar
Banned
Do you use a wheel cleaner ? that stuff can ruin plastic and eat it up.Do you use a hose and cleaners.?
Old Jan 22, 2005 | 10:15 PM
Cyril Baldwin's Avatar
I noticed it months ago that behind that cap, water accumulates alot after car washing my car. It may have been caused by car wash chemicals being accumulated behind the cap.
I made it a habit to removed the cap and dry the inside every after car washes just to prevent rusting of the bolt.
Old Jan 22, 2005 | 10:18 PM
Dan Root's Avatar
Banned
One more reason I don't hose my wheels clean ,check thread on brakedust.
Old Jan 23, 2005 | 08:19 AM
MARK_UK's Avatar
Could be the way I clean the wheels. I do scrub with WONDER WHEELS ( Do you have that in the US?) and I have used a Pressure washer a couple of times.
I wanna replace the badges with something else but can't get my head round thinking of something to fit.
Old Jan 23, 2005 | 11:28 AM
jkettle's Avatar
Mark
It is 100% without a doubt the result of Wonder Wheels! I knew as soon as I looked at the picture. I and my friend used to use wonder wheels until we all had the same problem. If that stuff gets into the smallest hole in rots your car from the inside. DONT use it!!!
Old Jan 23, 2005 | 12:26 PM
lordpercy's Avatar
Checked mine while cleaning all looks fine, i use halfords own brand cleaner for the alloys seems ok
Old Jan 23, 2005 | 08:02 PM
I just use dishwashing soap in my wheels and it worked so far. I've had bad experience with my other wheels using chemicals.
Old Jan 24, 2005 | 03:28 PM
garym79's Avatar
Mark, It's not the way you clean the wheels, they're just cheap crap. I've had mine replace by the dealer twice now and the third set appear to be OK, they won't have an issue with replacing them. Just ask for your old ones back and you can experiment with them.
Old Jan 24, 2005 | 04:02 PM
jkettle's Avatar
Garym79
I completely disagree, If you put acid on your wheels I don’t get every little drop off this will happen every single time. 99% of wheel cleaners contain some form of acid…. DON’T use them.
My advice is use to use water, a sponge and elbow grease.
Old Jan 24, 2005 | 04:11 PM
garym79's Avatar
Originally Posted by jkettle
Garym79
Jkettle,
I only use water to clean my wheels, explain that?!
Old Apr 13, 2005 | 05:22 PM
macjake's Avatar
Today I noticed the same corrosion on the front wheel caps. I have only ever used soap and water on the wheels, no acid based products. The wheels are waxed once a month so the brake dust comes off easily. I am an hour from nearest dealer who wants me to post the caps for inspection! then after analysis will order new ones if covered by warranty.
BUT
If this is not a known problem then why is it that the center caps are on back order and will take 15 working days to arrive.
While inquiring about the center caps I asked about the Startech Sports Exhaust, this can be with the dealer in 4 DAYS, the cost including fitting. ANYONE GUESS
£ 826.38
I'll ask next for price excluding fitting.
Old Apr 13, 2005 | 09:45 PM
Dan Root's Avatar
Banned
I can send you my Crossfire lazer cut ones. pm me if interested or DCXFIRE@aol.com
Old Apr 14, 2005 | 09:57 AM
norrie's Avatar
One of mine is like that and another is going that way.
Let me know if you have any luck claiming under warranty.
Norrie.
Old Apr 26, 2005 | 10:15 AM
r.robertson's Avatar
Mark got the same prob but, only have used wonder wheel twice but my problem is not as bad.
Old Apr 26, 2005 | 10:27 AM
xfired's Avatar
I beg all of you, please use nothing but soap and water on your wheels. I've ruined many wheels and had to learn the hard way about chemicals. I know the Crossfire is a brake dust making machine, but soap and water is all you should ever use. I've had my car a year now--4000 miles and the wheels look like day 1.
Old Apr 29, 2005 | 06:38 AM
I also use Autoglum allow sealer. It makes washing the alloys a heck of a lot easier.
