K & N Air Filters
Old Jan 30, 2005 | 06:02 PM
ninilchik's Avatar
Question K & N Air Filters
Does anyone know if the engine computer needs to be reprogramed with the addition of K & N Air Filters?
Old Jan 30, 2005 | 06:14 PM
vncntcox@yahoo.com's Avatar
Default Re: K & N Air Filters
no, just slap them in and let it breathe a little easier
Old Jan 30, 2005 | 06:23 PM
mbepic's Avatar
Cool Re: K & N Air Filters
Good question.
Some time ago I read that it is adviseable to disconnect the battery for a couple of minutes after installation of new intake/filter system. Can't remember if it was for Xfire or PT Cruiser (think it was for PT) but I believe it was on the K&N site that I read this.
You may want to investigate.
Disconnecting and reconnecting battery resets computer module to new airflow was the jist of the instructions.
Old Jan 31, 2005 | 02:27 AM
Steffen's Avatar
What is better if I install K&N filters to the stock air intake?
Old Jan 31, 2005 | 09:38 AM
andrew's Avatar
-C-I-C-C-I Associate Member
no need for reprogramming...i have been using k&n's for over 15 years.
Old Jan 31, 2005 | 11:17 AM
mbepic's Avatar
Originally Posted by mbepic
Good question.
I guess you can disregard my previous post regarding resetting computer module because the latest K&N site instructions for changing the PT intake air flow system simply says to disconnect negative cable on battery (presumably for safety reasons) and then at the end instructs to re-connect battery cable. No mention of computer module.
With K&N filter swap, you don't even have to disconnect battery (according to instructions).
I know I not mistaken as far as reading those other instructions a couple of years ago but it is quite possible that was erronious information at the time.
Old Jan 31, 2005 | 12:33 PM
stlxfire's Avatar
Has anyone had any issues using the K&N's? I recall on my Mustang GT the oil could
contaminiate the wire in the airflow sensor causing spark knock. Any such issues on the
xfire?
Old Jan 31, 2005 | 02:47 PM
ninilchik's Avatar
I checked K & N web site, which advises oil is not problem with K & N filters unless they are over oiled. There is a caution not to over oil.
Old Jan 31, 2005 | 03:30 PM
NJspeed69's Avatar
If you put in K&Ns and then unplug the battery so the car would reset, it seems to me like you'd LOSE power. The computer would sense more air coming in and so adjust the fuel or ECU or whatever to balance it out to normal. I can't see it increasing power.
Old Jan 31, 2005 | 03:37 PM
XFiring's Avatar
It does not matter if you unplug or not, if something changes the comptuer will 'learn' over time and adjust. unplugging just makes it sooner.
Old Jan 31, 2005 | 09:54 PM
mbepic's Avatar
Someone has deleted my two posts---mysterious!!
Old Feb 1, 2005 | 05:31 PM
mbepic's Avatar
Another post mysteriously disappears--spooky????
Old Feb 2, 2005 | 07:19 PM
convertiblenut's Avatar
what are the benefits of changing the stock air filter to a K&N air filter?
Old Feb 2, 2005 | 09:41 PM
the engine breathes in more air hence more power
Old Feb 2, 2005 | 10:24 PM
Bob G's Avatar
You might even gain a mile or so per gallon!
Old Feb 2, 2005 | 11:44 PM
mbepic's Avatar
You can clean the K & N and reuse; you don't have to buy another filter again.
Old Feb 3, 2005 | 05:32 AM
PJA's Avatar
PJA
How easy is it to change the filter(s)?
Pete
Old Feb 3, 2005 | 11:23 AM
luke646's Avatar
PJA,
Filters are very easy to change.
1. Remove engine cover. Just give it a good tug straight up.
2. Flip it over and unscrew the the air cleaner boxes.
3. Clean box and make sure area for filter rubber is clean.
4. Replace filters (By the way you will need two filters) and screw boxes shut.
5. replace engine cover - make sure clips are lined up and reconnect breather hoses.
6. Go drive!!!!!!!!!!
Old Feb 25, 2005 | 04:34 PM
slysop's Avatar
how much did your k & N cost and where did you get it
i am looking for a whole air intake kit if anyone knows of a good one
Old Feb 25, 2005 | 06:47 PM
ninilchik's Avatar
Purchased from autobarn.com. Requires 2 #332290 @ $30.60 each for $61.20 plus UPS freight to your location.
