Loose Sway Bar Linkage
Old May 26, 2005 | 03:41 PM
Rob M's Avatar
Default Loose Sway Bar Linkage
If you are hearing a clunking or thumping noise in the rear of your crossfire when making turns at slow speeds chances are you may have a loose sway bar linkage. It sounds almost like someone is under the rear of the car and tapping it with a hammer once as you turn. It started off intermittently but eventually could be heard every time I turned left of right. I had already read about this problem on a couple of other threads (which discuss a variety of unrelated noises as well). I took it in and the dealer re-torqued the links. The noise is gone.
#7851
velociabstract
16
Oct 12, 2015 10:56 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Abaton6
Sep 24, 2015 10:14 PM
RacerXofFL
Sep 15, 2015 05:00 PM
jaesa
Sep 7, 2015 01:50 PM
