I need help choosing manual transmission fluid
Old Nov 27, 2019 | 10:43 PM
Cotyt94's Avatar
Default I need help choosing manual transmission fluid
Yo,
been trolling through the posts, cant make sense of which fluid to replace mine with. 102k on the tranny, 1st and 2nd is a hard shift. Leveled the car, tranny is pretty dry. Read something about synthetic motor oil? Can anyone reply with a link to some good options.
Old Nov 28, 2019 | 09:13 AM
mountainbmike's Avatar
Default Re: I need help choosing manual transmission fluid
My other car is an older Miata and it's 5speed was trashed by the previous owner I tried 5 different fluids all synthetic and the best was redline MTL. It's thin but worked the best. My CF is an auto just thought I'd chime in.
Old Nov 28, 2019 | 09:34 AM
harbor's Avatar
I tried a lot of trans fluids and got the best result with factory MB gear oil from Needswings.
https://www.crossfireforum.org/forum...-question.html
Old Nov 28, 2019 | 11:25 AM
Cotyt94's Avatar
Thanks y'all!!! I'm hoping it's just a dry issue since i only started noticing hard shifts a few months ago. I never noticed the 1-2 hard shifts before like everyone talks about with our transmission. Knowing my luck though that's probably it :'D
Old Nov 28, 2019 | 06:04 PM
yellowhammer's Avatar
Royal Purple Gear Oil 75/90 WT. expensive but works great in manual transmissions and rear diffs.
Old Nov 29, 2019 | 12:12 AM
Start with the Owners Manual recommendations, then cross reference with the specifications, then get whatever you want after seeing that information. The 'minimum' is a 'baseline'. Your choice after that will be based of who and what convinces you on what to install in it. Good luck!
Old Nov 29, 2019 | 01:02 AM
Cotyt94's Avatar
I'm thinking of going with the amsoil 5w 30 synchromesh it's abbot 25$ for 2qts
Easley15
Feb 13, 2013 12:47 PM
a2izaemfan
Apr 8, 2011 11:02 PM
mrmiguel
Jun 20, 2009 07:39 PM
helma74
Jan 11, 2008 04:50 PM
ExPorsche
Jan 5, 2004 04:44 PM
