Wheel Spacers
My Friend Just Pick Up An Xfire And He Wanted To Add Some Wheel Spacers, But He Is Not Sure To Go With 10mm Or 12mm. I Did Not Want To Give Him Advice Because I Was Not Sure.
So Any Advice Would Help! Thanks.
Andrew had a 10 mm front and 12 mm rear. I'm waiting for mine to arrive this week with the same size as Andrew's. Here's Andrew's info for wheel spacers:
automotive wheel spacer DR-System H&R Trak+
Stock # 07-B9
Item # 2055665 (20mm 112/5 66.5mm) Mercedes (front)
# 2455665 (24mm) (rear)
*(equals 10mm or 12mm each side)
Lug Bolts (longer than stock)
Part # 1255001
i purchased mine through "tc kline racing.com" or 614.771.7744 ask for pete. nice to work with imo.
Stock # 07-B9
Part # 1255001
Originally Posted by michael savage
Thanks For All The Help, I Will Pass The Info On To My Friend. Do You Know How Much Andrew Paid?
Stock # 07-B9
Part # 1255001
Stock # 07-B9
Part # 1255001
Another "must have" for the CF nut! Thanks Andrew and Cyril!
I also installed the spacers but decided to go with 15 and 20 as i feel it was barely discernable otherwise.
The price was about $120 plus shipping for 4 hub-centric spacers with bolts from:
STEVE D MCNEIL
Company: ACCESSORIES PLUS
City: MURRIETA
State: CA
Country: United States
Phone: (909) 947-5115
The fit is beautiful and the ride is smooth...handling is really improved.
STEVE D MCNEIL
City: MURRIETA
State: CA
Originally Posted by rob05crossfire
I called this place and they don't carry the studs. They said, that it would cost $55 each = $220 for all 4 without studs. How did you get that price?
Originally Posted by MrQue05
HDDP,
Would you know if the 20mm spacers would work (look right) w/ 245 rear tire?
Thanks
Thanks
Well I've replaced my stock wheels with a 18" front & 20" rear combo (Detata Double-D (Black) a very nice wheel for the car). See gallery for pic. The fronts are fine but the rear has that recessed look and I want to line it up with the wheel well. I saw a previous post from Andrew which listed the following:
2003 m/b slk
bolt pattern: 5/112
center bore: 66.5
bolt
thread type: 12x1.5
width: 12mm
part number: 2455665
list price: $95. pair (less bolts)
So what's better, going with the 10mm (per side) or the 12mm?
2003 m/b slk
bolt pattern: 5/112
center bore: 66.5
bolt
thread type: 12x1.5
width: 12mm
I've got a pic in my gallery but it does not show all the angles...I'll post more pics tonight of the clearance from different angles then maybe you could shed some light. Thanks
I looked at your gallery. I don't think it's about wheel spacers at all, you have such low profile tires that it increases the gap in the wheel wells. I would drop the car by what appears to be about 2", or get larger sidewall tires to fill the gap. IMO...
My opinion doesn't count on this one, because we're into completely different reasons for modifying the car...
STEVE D MCNEIL
City: MURRIETA
State: CA.
STEVE D MCNEIL
City: MURRIETA
State: CA.
Thanks.
