Oil Filter Installation
Old Jul 8, 2005 | 01:03 PM
Heb80's Avatar
Default Oil Filter Installation
Where does the biggest rubber O-ring on the oil filter go?
1) All the way to the top of the assembly, on the ridge just below the cap. This scenario would make it so that when the filter assembly is installed you can see the rubber between the plastic cap and the metal housing.
2) Or does it go at the top of the threads, below the ridge. This scenario would make it so that it is recessed down inside the housing when installed.
Old Jul 8, 2005 | 03:14 PM
former NXMX5's Avatar
Default Re: Oil Filter Installation
well where did you take the old one out of?
IIRC, It goes just above the threads.
Old Jul 8, 2005 | 03:26 PM
Heb80's Avatar
Can't remember where it was from the factory. On my previous oil change I had it all the way to the top of the assembly, just under the cap, so that it squeezes between the cap and the steel housing and was still be visible when installed. This time I put it there and it leaked about a quart of oil (what a mess). So I just changed it so that it is in the space at the top of the threads on the assembly, so when installed it cannot be seen. It is down inside the housing... so far so good.
Could someone check theirs (assuming you haven't changed your oil yet) to see how it comes from the factory?
Old Aug 26, 2008 | 07:37 PM
Placement of large o ring for oil filter
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
Jul 29, 2015 06:13 PM
steps
Jul 27, 2015 03:14 PM
