sporadic rattle
Old Jul 18, 2005 | 01:01 AM
rpr1bob's Avatar
Lightbulb sporadic rattle
rattle every once in awhile, seems to be coming from the right rear area, like from the right rear corner of the hatch or fuel door? Anyone have this problem and the cause or fix for it?
Thanks.
Bob---- San Diego, Ca
Old Jul 18, 2005 | 08:27 AM
ben47's Avatar
Default Re: sporadic rattle
There is a TSB out which deals with a rattle from the hatch. They adjust the stops and replace the latch.
Old Jul 18, 2005 | 08:29 AM
chxf's Avatar
I had it too. My dealer fixed it. Don't know exactly how and what, but he told me they did something to the inside hatch cover. Next I'll have to be done is the rattling hatch lock replacement.
Old Jul 18, 2005 | 09:05 AM
dadof4's Avatar
I was able to eliminate an annoying rattle from the hatchback by lowering the 2 rubber bumpers on the hatch. It took less than 5 minutes to fix. To do it yourself you need a star wrench.
Old Jul 18, 2005 | 11:41 AM
christo76's Avatar
I have a rattle kind of noise when I accelerate harder. The techs fix was to put a bunch of grease where the bumpers contact. This didn't fix it, it just gave me a great place to accidentally get grease on my clothes.
Old Jul 18, 2005 | 06:00 PM
chxf's Avatar
Tried this too. I sprayed silicone all over the bumpers and the contact area. No effect. In my case it must be the latch.
@dadof4, what do you mean with "lowering the 2 bumpers"? Make them shorter or mount them in a lower position?
Old Jul 18, 2005 | 06:27 PM
dadof4's Avatar
The mounting holes for the bumpers are elongated. They were made to be adjustable. Hope this helps.
Old Jul 18, 2005 | 06:48 PM
chxf's Avatar
I'll check it out.
Cheers
Old Jul 18, 2005 | 09:52 PM
BullFrog's Avatar
christo76,
I have the exact problem your having only when you accelerate harder the noise is coming from the back and its pretty audible that my passengers ask "what's that?" I just picked up car from service and all they did was tighten everything and lube and it still does it.
Could it be the styrofoam sections under the trunk carpeting that are flexing and rubbing against body under acceleration???
Old Jul 25, 2005 | 08:42 PM
chxf's Avatar
Hey, thanks a lot! I did it and it works. No rattle anymore. But still gonna replace the latch as mentioned in the TSB.
Thanks...little fix - great effect!
Old Jul 26, 2005 | 01:50 AM
rpr1bob's Avatar
I attached a piece of tape to the rear hatch hand handle to keep it from moving horizontally. Rattle stopped.
Thanks.
I will have the dealer replace the latch handle.
Old Jul 26, 2005 | 02:04 AM
rpr1bob's Avatar
Lightbulb Re: sporadic rattle
Attached a piece of tape to the rear hatch hand handle to keep it from moveing horizontaly. Rattle stopped. Thanks
Old Aug 23, 2005 | 08:27 PM
chxf's Avatar
My hatch is definitely quiet now! It's about a week ago I had the rear latch replaced. I lowered the bumpers too. Not a single sound since.
Thanks for that advice.
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
sittininthesun
Aug 24, 2015 10:47 AM
UNDER PSI
Aug 1, 2015 02:11 AM
mobilefitt
Jul 28, 2015 03:45 PM
