starting issues
Old May 1, 2021 | 12:04 PM
MJinks's Avatar
Default starting issues
2015 crossfire will not crank. all other electrical working fine
Old May 1, 2021 | 01:04 PM
Default Re: starting issues
won't crank ( NOTHING happens when key is turned ) probably RCM
or
won't start ( engine turns over for more than 5 seconds but doesn't catch ) CPS or fuel issue or RCM
or
engine starts, but stops after 3-4 seconds, then will do same thing again, but then won't do nothing ( the dreaded SCREEM issue )
Old May 1, 2021 | 06:27 PM
tighed1's Avatar
MJinks
If you turn the key to the ON position and wait 20 seconds, does the radiator fan spin up REALLY fast?
Old May 1, 2021 | 09:08 PM
MJinks's Avatar
yes, every electrical item works fine. Just will not crank. I have seen three videos about this problem and everyone shows the same thing. Need to resolder two terminals.
Old May 2, 2021 | 01:43 AM
tighed1's Avatar
So, 'YES', the radiator fan spins up REALLY fast?
Old May 2, 2021 | 10:03 AM
You have been asked twice if the fan spins up to high speed when you turn the key "ON". Do you understand how hard you are making this for those trying to help you?
Understand that NONE OF US are standing next to your car, yet you expect us to help you figure out what is happening. We cannot do that if you can't answer simple questions.
Does the fan speed up in about 30 seconds or not? This tells us if the engine control relay output is not there, and it tells us if the switched ignition output to the FCM is there - these two pieces of information are fundamental to determining what is going on.
Old May 2, 2021 | 11:51 AM
So many ask for help and then don't many to hear the solutions.
Old Jul 9, 2021 | 10:12 AM
Grunts82's Avatar
I have an issue with my 04 base coupe, replaced rcm, ecm, skreem , ignition, fuses and battery... only thing left is the start and 10 month alternator?????
Old Jul 9, 2021 | 10:25 AM
What does it do, not do when you try to start it. What do you mean, replaced the screem and ignition?
Old Aug 15, 2021 | 05:00 PM
zujowro768's Avatar
My fan speeds high within the first 30 seconds of me trying to crank the engine over. There's no clicking from the starter. I thought it was my battery but my battery is fully charged. What is the skreem and it's function. And would it effect why my car is not turning over? Thankyou for the replies in advance.
Old Aug 15, 2021 | 05:58 PM
tighed1's Avatar
If your car is doing this (see video). Problem is the relay control module. I can fix it.
Email me at tighed1@hotmail.com for details.
Old Aug 15, 2021 | 06:23 PM
Yes, it is the RCM, not the screem.
Old Dec 17, 2021 | 07:44 AM
VintageBikesUSA's Avatar
I am headed out now to see if my RCM is the issue on the R170 I picked up in the rain yesterday. Thanks for the Video.
sama87
Apr 21, 2021 02:47 PM
gompang
15
Jul 27, 2019 02:18 PM
paulcross140
Nov 21, 2018 08:11 PM
vickisway
Jan 26, 2012 02:34 PM
kbbilode
Jun 13, 2009 05:03 AM
