Door/window seals and air noise…
Old Aug 3, 2021 | 10:05 AM
jasonk931's Avatar
Default Door/window seals and air noise…
Hey guys, I’m wondering the best solution to quiet the cabin when driving at higher speeds on interstate? Purchase some new seals all around or another route?
please direct me to where I might purchase new fresh seals for doors if able. Cheers.
Old Aug 3, 2021 | 11:07 AM
Jim Holian's Avatar
Default Re: Door/window seals and air noise…
jasonk931 - I'm with you on this concern. These cars are NOISY on the road. I have a coupe and have put sound deadening sheets on the trunk floor and side panels to no avail. Didn't quiet the interior at all. If you have some success let us know what you did.
Jim
Old Aug 3, 2021 | 11:21 AM
I just switch of my hearing aid, the ride is then quieter than a Rolls Royce.😉
Old Aug 3, 2021 | 11:35 AM
Ronman's Avatar
Most of those parts are discontinued/NLA or insanely expensive if available and used ones are probably in worse shape than yours. There is a thread where someone put some extra weather-stripping under the existing seal at the top of the window and claimed he bought it from Autozone but never followed up with which one.
Old Aug 3, 2021 | 11:45 AM
jasonk931's Avatar
Ahhh! Good idea. I have some of weather stripping so I will give it a shot and report back.
Old Aug 3, 2021 | 03:11 PM
zip439's Avatar
Here is a PDF from onehundred80 which may be of help : window adjustment
Old Aug 4, 2021 | 01:35 AM
One extra bit of caution? Adding anything in the existing seals might result in a leak or tearing of the existing weather-stripping. If you store your car outside normally and you do 'stuff' additional anything in or around the weather-stripping, check for water intrusion when you open the doors, often.
Old Aug 17, 2021 | 10:20 AM
jasonk931's Avatar
Added a small bit of seal trim under old seal and it helped massively. I still have a bit of wind noise, but I targeted the problem. I taped a shield of sorts along the outer window ridge to create a deflector. Testing it, it produced pure silence in the cab! So, I need to find a deflector/Rain Visor that can fit. Preferably something that isn't outlandishly big and non-asthetic. I checked online and it seems these are not available for window trims of Crossfires. Is there a model of another vehicle that might fit or do I need to look at self fabrication?
Penniman
Oct 1, 2013 03:56 PM
Penniman
Aug 10, 2012 11:05 AM
LeePie
Dec 16, 2008 03:00 AM
cassidyrj1
Sep 29, 2008 12:04 PM
Galen Dracos
Oct 31, 2003 11:44 AM
