Trunk plastic fasteners where to buy?
Old Mar 25, 2022 | 09:44 PM
nickwe21's Avatar
Default Trunk plastic fasteners where to buy?
Where can I buy the little black fasteners? Not sure why but they are all missing in my friend's Crossfire.
see pictures please. Does AutoZone have something that fits? Or does it need to be Mercedes specific for best fit?
Old Mar 26, 2022 | 10:05 AM
zip439's Avatar
Default Re: Trunk plastic fasteners where to buy?
Gentle pull a good one out to check size and shape. You can then buy a generic fastener that looks similar. while at the auto parts store get a set of plastic/vinyl tools made for removing those clips and other body panels without damaging the under parts. You pull the center piece of the fastener out first. Do not get behind the entire face of the fastener and try to remove it. Pull the center piece out which will allow the tabs on the inside to reduce in diameter and then work the fastener out of the hole.
I just removed one from my car. The fastener is actually two separate pieces the large piece will fit in the hole first then the center piece will slide into the first and expand the tabs on the plug. The diameter of the first piece, the plug is 7mm. If you have any silicone grease use a dab on the plug and the slide as it will make removal much easier should it be necessary sometime in the future.
Old Mar 26, 2022 | 11:45 PM
nickwe21's Avatar
So hard to find these...went to AutoZone and wasn't able to find anything that actually matches. The screws look similar but won't hold we tight as these.
DId you buy some new ones? If so where?
Old Mar 26, 2022 | 11:50 PM
I got mine from eBay, they are cheap. The size is 8 mm. Push pin clips or rivets.
I will look tomorrow on eBay for them.
Old Mar 27, 2022 | 12:23 AM
Ronman's Avatar
These are not hard to find, your local Mercedes dealership will have them in stock MSRP is 1.90 each, Autohausaz or eBay. Part number is 2309900192
https://www.autohausaz.com/pn/2309900192 so you can see what they look like.
Old Mar 27, 2022 | 11:13 AM
Creds to Ronman, check these (https://www.ebay.com/sch/i.html?_fro...Desc=1&_sop=15). Good luck!
Old Mar 27, 2022 | 10:40 PM
nickwe21's Avatar
Guys thanks so much. I ordered a couple of packs..will be nice to not feel all the panels in the trunk rattle around all loose. Appreciate the help!
Hindin
Jan 7, 2021 08:25 PM
Johnny Versatile
Mar 5, 2020 02:24 PM
UrbanE
Sep 1, 2018 01:42 PM
onehundred80
Aug 28, 2018 01:50 PM
Rapps
Oct 17, 2007 06:55 AM
