wheel spacers - size & cost
Old Oct 3, 2005 | 08:43 AM
typhoon55's Avatar
Default wheel spacers - size & cost
20mm in rear and 17mm in front is definately the way to go. Do not think less as you will regret it. They line up with the outside fender. If you slam it then this may not work!!
I have found the hub centric - (4) delivered under $150! This is less than half of the H & R spacers.
Also easy to install . It really gives noticeable handling improvements and the wider stance is really nice!! It drives as smooth as without the spacers.
So for anyone interested, it is a DIY low cost mod upgrade for real performance and asthetics.
Old Oct 3, 2005 | 09:03 AM
danimal's Avatar
Default Re: wheel spacers - size & cost
Originally Posted by typhoon55
20mm in rear and 17mm in front is definately the way to go. Do not think less as you will regret it. They line up with the outside fender...
Pictures???
Old Oct 3, 2005 | 10:06 AM
andrew's Avatar
-C-I-C-C-I Associate Member
personal preference...i don't regret it. 10 & 12mm work great, for the look i prefer.
regardless...i am glad you are satisfied with the size you selected.
cheers!
Old Oct 6, 2005 | 03:39 PM
bizzelz's Avatar
Pictures??
Old Oct 6, 2005 | 05:58 PM
pavespike's Avatar
Post Pictures???
Old Oct 6, 2005 | 09:06 PM
former NXMX5's Avatar
Old Oct 7, 2005 | 04:28 AM
pnsji's Avatar
20mm in the rear should be okay. I think I use more than 20mm.
Here is the result:
Old Oct 7, 2005 | 07:44 AM
typhoon55's Avatar
Originally Posted by former NXMX5
thats pretty funny!
Old Oct 7, 2005 | 08:34 AM
that's with an aftermarket rim though. would it be similar with the stock rim? i've seen andrews pics and they look pretty good. i haven't seen a 20mm on a stock wheel --
Old Oct 7, 2005 | 02:55 PM
pnsji's Avatar
Even my aftermarket wheels has a lower offset compared to OEM wheels.
So 20mm on my wheels means thicker spacers for OEM wheels.
Plus my aftermarket is wider than OEM.
Old Oct 7, 2005 | 03:01 PM
pnsji's Avatar
from andrew's picture:
Looks like there is a good 10mm gap between tires and fender.
Old Oct 7, 2005 | 08:12 PM
ViffeR's Avatar
OK, so where do we order them from? $150 shipped... sounds like a decent deal.
BrenLW
Aug 5, 2015 04:53 AM
onehundred80
Canada
Jul 24, 2015 03:50 PM
crymar
Jul 17, 2015 08:46 AM
syfi
Jul 12, 2015 05:59 PM
Buchacho
Jul 9, 2015 04:13 PM
