2005 limited fog lamp assembly
WantedAccessories
Description:
Looking for a passenger side, fog light assembly. Probably used, new ones are costly
2005 Limited
thanks
Good luck with your search, maybe you could find one at that price in wreckers yard, buy the other side as well if you can.
Jumping in, I just bought a 05 SE. The head light **** shows a fog light position and there are black blanks where the fog lights should go. My guess is the lights are wired but not installed. I would like to confirm the plugs are there and buy a set of fog lights. Any idea where to start to look for them?
There are a couple of options available that fit the Crossfire Fog Light Openings. And to add Fog Lights rather than replace OEM Fog Lights, you'll probably need to install an 'Add A Circuit' wiring harness to connect to the Fuse Box in the Engine Bay (I think). Search the Forum - Others have already done DIYs that you can follow.
Option #1 - BlingLights
Option #2A - Fog Light Adapters
Option #2B - Morimoto XB 70mm LED Fog Lights
You can also search Seller - Quirk Parts on eBay. They bought up quite a bit of Crossfire Parts Inventory several years back. Fog Lights listed below are new. Otherwise, as others have stated , look around eBay &/or 'bone yards' to find good used ones.
PS Fog Light
DS Fog Light
PS Fog Light
DS Fog Light
PS Fog Light
DS Fog Light
PS Fog Light
DS Fog Light
