DRB Emulator, Dell 11 Tablet with Keyboard
For SaleMiscellaneous
Description:
The Title says it all.
DRB Emulator, Dell 11 Tablet with Keyboard. Can be used as Laptop or Tablet, Keyboard is removable. There is a battery in both the keypad and behind the screen.
Currently running Windows 10 with all updates. Emulator files from OBD365
Not included;
-Power supply. They are available on Ebay for $30 or less
-Micropod. This has been tested on 2 separate micropods. Both from OBD365 and Both have had the solder mod completed.
Can Zoom to see it in operation.
Shipping from Canada
I am surprised that there has been no taker on this. With all the problems posted I would think it would have been long gone. I have not used mine as I have not used mine other than to plug it in and go through the menu.
I must add my thanks to you again for my one.
Four and a half months have gone by since it went into the garage on November the first. Two more months to go at least, as it only comes our after a couple of good rainfalls.
I am wondering if I should just replace the broken bulb in the headlight, replace both with the HID bulbs that were fitted to my NA st one time or replace them with LED’s. Decisions, decisions.
On my NA the headlight bulbs failed within two weeks of one another. The SRT was running with odd bulbs, I was comparing two Sylvania types to see which appeared brightest, I. could see no difference so I left them in, I wonder which of the two failed, the bright one or the so called brightest.
Peter, this says for 2004-2006. I have a 2007 coupe Limited. Will this work for that year? Would this be better than, say, a complete SDS or Xentry system for MB? Is there a micropod that you recommend? How about operating instructions? With only 18,000 miles on my coupe I'm only just needing to get into any in-depth DIY. In this case it seems to be more age related than mileage related. Just spent a while researching and fixing DTC code 2017, Intake manifold Runner Sensor and P0171, fuel system too lean bank 1. Seems it was the MAF needing cleaned and maybe a poor seal by the rubber seal around the MAF from the engine cowl. there was a bit of black soot in the MAF. Would this DRBIII emmulator have found this? I spent hours online researching all around the issue before figuring it out (hopefully).
There are several options for Micropod.
if you go down this road, PM me and I’ll send you a few links. They are available from several sellers.
With respect to your questions, I have both DRB AND SDS
there is overlap but they’re different. I planed on keeping and maintaining my car long term so I’ve acquired both.
It comes in handy. I’ve recently installed new tpm sensors on all four wheels and synced them in less than 2 minutes.
The best answers to your questions can be found online, visuals are available on YouTube.
it’s a great tool but I would encourage you to do your homework to ensure it’s right for you.
Hey @UrbanE ! (also @xfClifford , if you happen to be around here):
Someone posted a question (last year) in this thread I would be interested in getting answered. Question is: Does the PC based DRB III Enhanced Emulator work on 2007 and 2008 model year Crossfire?
I have an old laptop with the software installed somewhere, and the China cloned microPOD, but that stuff is hiding right now, and my 2005 Crossfire is resting (and it is too cold here now, anyway). My original dealership type DRB III (and Crossfire software card, with Multiplexer "cable") very likely would NOT work, because at least some Crossfire canBUS stuff was changed for 2007 model year. But the DRB III Enhanced Emulator for the microPOD system didn't come along for Chrysler dealerships until many years later, so by rights it SHOULD be able to work on 2007 and 2008.
Anyone around to confirm this? Thanks!
I must defer to another member, as I do not know for sure
I do know it works for the 05 and 06
but I read somewhere that the 07 and 08 might be different.
