Intake or no intake
Old Jul 9, 2007 | 02:14 PM
Sinners's Avatar
Default Intake or no intake
I have recently been pondering whether or not i should invest in a set of intakes for my xfire. What is the general consensus on this? I would think that it would almost make it worse due to the fact the it would then suck hot air straight from the engine bay. Would fabricating a heat shield on the stock intakes help? Any ideas on how to make this work?
Old Jul 9, 2007 | 05:41 PM
RPM's Avatar
RPM
Moderator
Default Re: Intake or no intake
I've been thinking about this a little bit too.
It is a good setup already, but wrapping the tubes in a 'heat shield' type material would probably help. Also, moving the intake holes directly behind the grill may help too. Not sure of any of it though.
Old Jul 9, 2007 | 06:13 PM
intenseblu's Avatar
its a sound modification... if you want to add the growl without reducing power take your stock intake and flip it, the center lid is removed by removing the torx screws around the edge. inside you will find a set of channels that keep the air flowing in a relatively straight path to the throttle boyd ... dremel these out and presto, you have growl ... add some k&n filters and you have some more growl. then buy some DEI thermal tape and cover the entire center lid and air boxes with it and you'll keep your air supply from becoming heat soaked in traffic (or at least make it not as bad hah)!
Old Jul 10, 2007 | 10:22 PM
Goldwing's Avatar
Are you going for noise or performance?
If the former, drill holes in your muffler.
If the latter, don't you think DC would have done this cheapo "upgrade" if it actually improved performance?
I made the mistake of ripping the smog gear off of my '82 CJ7 and drilled lots of holes in the air intake of my '77 Goldwing, neither really worked in the end. The CJ7 was faster but the mileage tanked. And the 'Wing ran worse and eventually the dealer taped over my brilliant holes.
IMHO, the stock car has a great growl.
Old Jul 10, 2007 | 10:31 PM
acrispy1's Avatar
This is what I have.
I don't know if you had this in mind, I didn't notice any performance change but it does sound nice. I did it for the look.
Old Jul 12, 2007 | 12:57 AM
jonnyangel04's Avatar
I have a single intake that I have designed and created I also have a duel kit that bolts right up along with sensor ports. Both pictures of single intake and then photoshop of the dual. I am going to start selling them on ebay let me know if anyone is interested.
https://www.crossfireforum.org/forum...ad.php?t=16592
Sep 28, 2015 07:40 PM
Ralph289
Sep 21, 2015 09:34 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
Idrenak
Sep 19, 2015 08:17 PM
RacerXofFL
Sep 15, 2015 05:00 PM
