Roadster needs Help, excessive tire wear
Old Jul 13, 2008 | 03:24 PM
stlas69's Avatar
Default Roadster needs Help, excessive tire wear
I have a 05 with 6800 miles, stock suspension. while traveling last week I hit a major storm outside Milwaukee and started to hydroplane around 50 mph. When I got home I took a good look at my tires and found the front tires were worn on the outside edges and were down to the wear bar on both sides. the rear tires, the tops are tilting inwards and the inside of the tires are down to the wear bars. what's left of the tires are around 6/32. I serach this site and read all the notes concerning tire wear, some say it can be aligned, other say nothing we can do, and other say we need some sort of alignment kit. I understand that the Continentals are not a good tire. I'm going in sat for an alignment and putting on new Goodyear Eagle F1's. Does anyone know if any of the manuels have a std alignment spec? I can't afford to do this again in 7k miles after spending $1100 dollars for the new tires.
Thanks for your help.
Mark
Old Jul 13, 2008 | 03:41 PM
maxcichon's Avatar
Default Re: Roadster needs Help, excessive tire wear
Replacing the Conti's is a great decision. My rears were worn to 4/32 after about 15K, but the fronts look like new. Still do in fact, as I removed them and replaced with Falkens.
Maybe you can find the alignment specs here:
http://homepage.mac.com/gregmeach/XFire/
And as for the 6800 miles: I don't see how, without excessive autoxing, they could have that much wear. Sounds like something to definitely persue.
Best of luck and let us know?
Old Jul 14, 2008 | 02:01 AM
crossfirefun's Avatar
Something is def. wrong there. Mine has a tick over 5000 and the tires still look new.
Even the rears that have a tendancy to make funny noises when I take off.
Old Jul 14, 2008 | 05:08 AM
I think you need an alignment. I have the Conti's, and while they would not have been my first choice still look like new after 22K miles. I don't think it's the tire. If you don't get to the root of the problem, you will go through this again soon.
Old Jul 14, 2008 | 05:42 AM
I have 33,000 on original tires and no uneven tire wear at all
Old Jul 16, 2008 | 03:13 PM
Goldwing's Avatar
29k miles and still original Contis. Not down to the wear bars. But I did mostly highway driving on them. I may get them again, but will also look at some of the summer tire jap brands when the time comes to replace.
Let us know if rear alignment is possible. I doubt it.
Old Jul 17, 2008 | 06:28 AM
gfalcone's Avatar
I got the connies' on my car but I just got it so I don't know how old the tires truely are....but I'm just about 38,000 and they "appear" fairly good shape...no ware bars as of yet.
Old Jul 17, 2008 | 06:43 AM
maxcichon's Avatar
Watch the pop-up rain storms, my friend! The Contis are not so hot in the wet. You can swap ends so fast, you can read your own license plate.
Experience speaking. For once.
Where in Ala-by-god-bama are you?
Old Jul 17, 2008 | 08:32 AM
RPM's Avatar
RPM
Moderator
Could be a steering stabilizer issue (if you search for it, you will find it. I think 'NeverEnough' may have started the thread).
I've got ~6,450 miles on my Contis (and the car) and they have worn great.
I did get caught out in the rain once (Woodward 2007) and they performed horribly IMO.
Good luck.
Old Jul 17, 2008 | 06:22 PM
stlas69's Avatar
Follow up, took the car in today for tires and the alignment. Front tires off on both camber and toe and the rear tires off on toe. Steering wheel is straight again and the rear tires are just slightly tipped in. the shop found no reason why tires were off that much to destroy them in that amount of mileage. I will do some tire wear measurements myself and maybe spend some money and bring the car in next summer for an alignment check just to be sure. I got a copy of the new measurements so I have something to compare the next one too. Thanks for everyones thoughts.
mark
Old Jul 18, 2008 | 08:58 AM
gfalcone's Avatar
mark
Dang hope that settles it then. You go with the eagles or stay with the cont's ?
Old Jul 18, 2008 | 11:00 AM
stlas69's Avatar
Eagles F1's
Old Aug 2, 2008 | 01:45 PM
Membrillo69's Avatar
Stlas69...nice name =)
I have Toyos on the front, Potenzas on the back..after about 10k miles mine need to be replaced aswell..I suspect Kauffman Tire put it on wrong..When I get my new tires im taking it to the Mercedes Dealership
IGot2P
Jul 26, 2025 12:40 PM
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
nickwe21
39
Jul 31, 2015 01:48 PM
cjfine
Jul 20, 2015 11:58 PM
