Tpms
I'm sure these questions have been asked before however sometime members have improved on or learned more about prior responses. With winter coming and some folks having extra wheels and tires for bad weather etc., some of the questions are.
(1) If you have TPMS sensors on more than one set of wheels, do you have to have the programming reset everytime you change wheels or will the system reprogram itself? Can the owner reprogram it? (2) If you want to go without TPMS on your extra set of wheels and tires, is there a fuse or connection you can remove so the light does not stay on / burn out? (3) Does the TPMS interface with any other on board systems? |
Re: Tpms
