Lubricating door limiter ... How to do it?
Old Apr 12, 2010 | 06:06 PM
popeye's Avatar
Default Lubricating door limiter ... How to do it?
Door limiter on driver side has started to click. Needs lube. Most cars have the notches exposed near the door hinges, but crossfire hides the notches inside the door. Anyone have experience with getting lube on these notches so they stop clicking?
popeye
Old Apr 12, 2010 | 07:22 PM
Raz83's Avatar
Default Re: Lubricating door limiter ... How to do it?
I used a spray lube on mine it came with one of those little red extension straws that get to the hard to reach places got it from autozone I can't remember the name I lent it out and it never came back but check autozone hope that helps.
Old Apr 13, 2010 | 06:47 AM
popeye's Avatar
Thanks mate...I did that very thing with WD40 and the red straw. Unfortunately I apparently never got the oil on the righ parts inside the door. It is impossible to look into that square hole, but I did use a dental type mirror and flashlight and saw some of what's in ther. Unfortunately I need to be looking at the same time I am spraying or I miss the spot that is dry. I have looked at figer optic inspection cameras, but at 200 to 300 dollars a pop that's not gonna happen. I guess it will just click and I'll get used to it. It is the only thing that's ever gone bad in my Crossfire roadster....Thanks again mate....popeye
Old Apr 13, 2010 | 07:18 AM
Raz83's Avatar
Smile Re: Lubricating door limiter ... How to do it?
Don't use wd40 it can actually make it worst there are other lubes that are in spray form I believe u need lithium grease spray they sell simillar sprays like it at autozone no problem I help when I can
Old Apr 13, 2010 | 03:00 PM
waldig's Avatar
Talking Re: Lubricating door limiter ... How to do it?
I recommend white lithum grease in the spray can. Have the window UP and spray away as you PULL the straw out. The splatter will coat the assembly all the way to the door hinge area, and not ookie up the glass. Taaa Daaa W DY
Old Apr 14, 2010 | 09:35 AM
popeye's Avatar
Well, thanks mates. I had a spray can of CRC white grease and that little red straw was still attached. I gave her another go and by golly I got lucky. The click is gone and I am a happy camper. WD40 just ran out the bottom of the door, and I think it did tend to make it worse.... Good lesson and thanks again...Popeye
PimpDaddy
Sep 29, 2016 11:55 PM
Bayukbros
Jul 29, 2015 10:16 AM
pioneer4x4
Jul 27, 2015 02:04 PM
Bayukbros
Jul 17, 2015 04:22 PM
GWAPA
Jul 8, 2015 07:25 PM
