Clutch Bucks During Acceleration Between 1st And 2nd
Old Dec 24, 2010 | 12:44 PM
dkriegh's Avatar
Default Clutch Bucks During Acceleration Between 1st And 2nd
Trying to sell my 05 Limited Roadster.....Had a person to come take it for a test drive...upon there return they told me they didn't want the car beacuse the cluch bucks between 1st and 2nd during high performance take-offs....
Is anyone having this problem or is it just me...wonder if there was any recalls on this item?
Old Dec 24, 2010 | 01:21 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Clutch Bucks During Acceleration Between 1st And 2nd
May have been their shifting/clutch ooperation. Did you not go on the test drive with them? Have you ever experienced this issue yourself?.
Maybe just a TEST PILOT's reason not to buy it
Old Dec 24, 2010 | 01:22 PM
6000rpm's Avatar
Every manual tranny car I've ever driven seems different, but I guess that's no surprise. I have an '05 Coupe. When shifting into second, I always have to make sure I push the clutch in before letting off the gas pedal, not at the same time, or the car sort of bucks. Maybe it's just me. These are no high performance take-offs, just nice and slow. I'm certainly no expert driver.
Tom
Old Dec 24, 2010 | 01:52 PM
Tom
I have a problem with that statement....I could see the clutch slipping....they don't buck...drivers buck.....is the clutch not engauging? You are the seller, any problems with you driving it? Need more info on this one...
Old Dec 24, 2010 | 02:14 PM
I have had similar experiences, as the car is jerking forward your foot does not keep the same extent of depression on the clutch as you tend to go back in the seat, this appears to start a chain reaction of jerks which only ceases when you fully engage the clutch or disengage it entirely.
It's basically the learners jerking attempt at clutch release.
Poor or broken engine mounts are also liable to make this happen as well.
dkriegh's Avatar
I know how to shift and it's either in the Transmission or cluch. It's almost like it drops out of gear for a second or to while going from first to second...even slow acceleration it will happen sometimes...
Old Dec 24, 2010 | 02:20 PM
It does go out of gear when you go from first to second, this statement does not match your first one somehow. I know things like this are hard to describe but .... something is missing.
Old Dec 24, 2010 | 04:21 PM
Kodebuster's Avatar
If I recall, I believe there was a TSB on the tranny/clutch on going from 1st to 2nd.
If I get a chance I'll try and locate.
(It's xMas eve and I got a ton of relatives decending on my place, so I'm going off the air...lol)...
Old Dec 24, 2010 | 09:25 PM
Ok, so it is "slipping" if it isn't engauged...broken spring on the clutch, which could cause it to chatter, or maybe something else...but either way, it will be hard to sell unless you fix it...
Old Dec 25, 2010 | 11:49 AM
Kodebuster's Avatar
Here is the TSB I mentioned above:
SB_21_001_05 ~ Manual Trans - Gear Sound When Shifting
All of the TSB's can be found here in PDF format:
https://www.crossfireforum.org/forum...ollection.html
There are a few other tranny related TSB's but they don't seem relevent...
TOPLESS
Feb 9, 2016 11:28 AM
jimf
Oct 10, 2015 10:22 AM
o55ie18
Oct 5, 2015 05:50 PM
Calitony
Sep 24, 2015 12:53 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
