washer fluid
Old Mar 13, 2011 | 09:39 PM
Mario1007's Avatar
Default washer fluid
Has anyone had trouble filling they washer fluid, i went to add washer fluid and all the fluid leaked under the car.
Thanks
Old Mar 13, 2011 | 09:48 PM
Default Re: washer fluid
Thanks
You can not top off your washer fluid on the Crossfire.
There is an overflow on the side of the reservoir and it won't allow you to fill it to the cap.
When it spills out onto the floor you have overfilled it.
This is a commonly asked question here.
Old Mar 14, 2011 | 08:03 AM
6000rpm's Avatar
An idiot light will tell you when it's low. You can't even see the washer fluid level when you look under the hood!
Tom
Old Mar 14, 2011 | 08:04 AM
mdaniels4's Avatar
If you live in a cold climate your fluid may be frozen which is why nothing comes out of the nozzles but when adding like gary said it runs out the side because you're alreaddy full. The other possibility is the bottle itslef is cracked.
Old Mar 14, 2011 | 08:12 PM
Mario1007's Avatar
Thanks for the help
Mario
Old Mar 14, 2011 | 08:29 PM
green-ghost's Avatar
drain it and save weight
Old Mar 14, 2011 | 08:32 PM
bluecoupe's Avatar
I had the same problem when I brought the 6 up from Florida, the washer bottle musta had water in it cause it froze up solid. I never thought to check when I picked it up, never occurred to me that there might be water in it instead of WW fluid.
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
Sep 26, 2015 10:21 PM
Jackobo
Sep 24, 2015 10:21 PM
