Tire Question
Old Jul 14, 2011 | 01:26 PM
OldSalt's Avatar
Default Tire Question
My 07 Roadster has OEM Conties on it. I need to replace the front tires only. I have gone to my local shops and one of the stores told me that I should not mix brands. He said to keep Conties all the way around or there will be handeling problems. Is this true????
I have had may cars with different brands and tread on them but not a sporty car like a XF.
So many brands to choose from. I am not a real agressive driver and 99% of the time I do the speed limit.
I finally got my XF on road and I am loving every second of it.
OLd Salt
Old Jul 14, 2011 | 01:42 PM
mdaniels4's Avatar
Default Re: Tire Question
not true, just the same on the fronts and thesames on the back. I have conti DWS's all around and I like them alot. Only performance tire that I know of outside of the Michelin Pilots that have a warranty. 50k
Old Jul 14, 2011 | 01:52 PM
OldSalt's Avatar
We have a new tire store called Tire Discounters. I got some prices on various tires. They offer a Kumho Ecsta LX Platinum with a 60K tread for 178.99 ea. Add 18.00 for road hazard for the life of the tire. Not a bad looking tire but I do not know much about this brand.
I run Michelin on the wifes S80 T6 Volvo and have had good results with them. Michelins in that size are 265.99 for the Polot Sport A/S+. So many choices
OldSalt
Old Jul 14, 2011 | 02:01 PM
mdaniels4's Avatar
others can comment better than I but from what I've read it's a good tire
Old Jul 14, 2011 | 02:08 PM
maxcichon's Avatar
Kuhmo, Hankook, Michelin...I would go with Kumho for the price-and many here like them. But I would make sure that same style is available in our REAR size just to be sure when you replace them-they match.
I looked-they don't.
Old Jul 14, 2011 | 04:20 PM
tom2112's Avatar
She can ride with me ;)
That is total baloney!
You can mix brands without any problems - front to rear. What he should have told you is that you should not mix traction/speed ratings. If your rear tires are Z rated summer tires, get Z rated summer fronts. If they're W rated all-seasons, get W rated all-season fronts. It doesn't matter if your fronts are Michelin and backs are Conti, or any other combination of brands.
The reason you should not mix traction/speed ratings is because if your rear tires grip better than your fronts you will understeer. If your fronts grip better than your rears you will oversteer. Remember: major oversteer is when you back end slides out on you (donut style) - major understeer is when you turn the wheel and keep going straight (like driving on ice).
Old Jul 14, 2011 | 04:31 PM
harbor's Avatar
Tire Rack - Your performance experts for tires and wheels
Kodebuster
Nov 5, 2020 04:06 PM
xfireohio
Jul 20, 2020 12:03 AM
MAXIMUM
Aug 4, 2015 11:04 PM
Bayukbros
Jul 29, 2015 10:16 AM
axnguyen
Jul 21, 2015 11:41 AM
