Water logged
Old Oct 27, 2013 | 11:09 AM
JONMAZARICOS's Avatar
Unhappy Water logged
Hi, just bought my second hand 2006 roadster (UK Spec) and at first sight of rain found drivers side carpets water logged. has this happened to anyone??? Is it a common problem??
Anyone have any ideas of what it can be??? or what its cause is??? coz im baffled cant see anything obvious...
Please help we only have lots and lots of more rain to look forward to.
thanks.
Old Oct 27, 2013 | 01:53 PM
Default Re: Water logged
thanks.
On left hand drive cars water gets into the right hand side of the car when the drain under the cowl in front of the windshield gets blocked and water goes into the heater/AC air inlet. With your car I am not sure what side of the car the inlet for the heater/AC air comes into the car.
Old Oct 27, 2013 | 03:54 PM
Wolf1608's Avatar
Hi,
On our UK models the heater fan in on the passenger side (left hand side of the car when viewed from the back). As OneHundred says the area below the windscreen has 3 drains which are hidden below the plastic scuttle plate underneath the wiper arms.
Really you need to lift the hood/ bonnet right up vertically, remove the wipers and then the panel to clear out the drains.
There is one other place that water could be getting in on the drivers side. There is a fuse box in the engine bay which I have heard can let water in if the lid is not seated properly.
Hope you get it sorted.
Matt
Old Nov 3, 2013 | 10:30 AM
thanks for the replies, you were spot on. The drainange was completly blocked. much appreciated.
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
cppeabody
Sep 15, 2015 08:43 AM
williammt
Sep 6, 2015 11:23 AM
sk8erjosh09
Sep 4, 2015 09:24 PM
Aug 31, 2015 11:12 PM
