Small Issues - trunk lid
Old Feb 15, 2014 | 12:03 PM
g3air's Avatar
Default Small Issues - trunk lid
Noticed a couple of things today when I opened the trunk lid.
First of all, the "E" letter of the "CROSSFIRE" lettering is a bit loose. You can see it here:
The "F" is also a bit loose. Any thoughts on how to remedy?
Also, I took the access panel off the underside of the truck lid to see if there was any access to the inside area where the lettering was fastened - there is not. But I noticed some dried up residue which appears to come from the gear transmission area of the spoiler raising mechanism, as shown here:
and here:
and here:
Any thoughts on the cause (heat damage to lubricant)? Needs a remedy? Spoiler still seems to work fine.
Old Feb 15, 2014 | 01:05 PM
robby363's Avatar
Default Re: Small Issues - trunk lid
You can fix the letters with some 3m double sided molding trim tape.
Old Feb 15, 2014 | 01:26 PM
dtinker's Avatar
The lettering can be reattached with 3M tape. You cut a piece the size of the letter and use an EXACTO knife to cut out the excess tape. I do these a lot, works very well.
As for the spoiler area, looks like a water leak to me. check around and see what you can as far as where it is leaking. I would use some white lithium grease and lube up as best as I could with out over doing it. Should be fine, just find the source.
Old Feb 15, 2014 | 01:37 PM
They are not just loose they are practically free already and may decide they want a life on the open road.
Take them off before they are lost.
Fix the leak soon.
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
55chevy
Nov 22, 2015 02:53 PM
Xfirenewbie
U.K.
Aug 13, 2015 04:39 PM
tom2112
Jul 12, 2015 04:41 PM
