2007 Crossfire Alarm Issues/Key Fob does not work
Old Feb 17, 2014 | 09:12 PM
OldSalt's Avatar
Default 2007 Crossfire Alarm Issues/Key Fob does not work
I go to get n the car and the key fob does not work, I use the key to open the door. Alarm goes off. Go to start the car and engine starts the battery dies, Try again same thing, now nothing. Get all the idiot lights but will not start. No click, no starter nothing I replaced key fob batteries, still nothing. Been looking at a few threads and most folks say replace the battery. Yup, its an 07 with the original battery. Started fine today, no indication of bad battery. Now it did rain like a wall of water for about 15 min. Any idea if something got soaked. I plan to check out the engine compartment tomorrow morning. I have a fluke digital VOM and plan to check the cells for a short.
Thanks
Old Salt
Old Feb 17, 2014 | 09:21 PM
Padgett's Avatar
Default Re: 2007 Crossfire Alarm Issues/Key Fob does not work
Starting and RKE all come together at the SKREEM. See the diagnostics in the service manual. Hard to fix if not broke.
Old Feb 18, 2014 | 07:03 AM
gualtira's Avatar
Try the Following from a previous post:
Chrysler Crossfire switchblade remote key starts the engine but the remote doesn't work.
The switchblade remote key can lose it's synchronization if the buttons are pressed too many times when not in range of the vehicle. If this happens the solution is to simply resynchronize.
Resynchronization:
  1. Insert key into ignition. Don't turn it.
  2. Press the lock button on the switchblade remote key twice in 2 seconds.
  3. Turn the key to ON or RUN within 30 seconds.
  4. Take the key out. Exit vehicle and have the doors closed. Test the remote.
Old Feb 18, 2014 | 11:51 AM
OldSalt's Avatar
Turned out to be a bad battery. Auto Zone charged it for 3 hours and ran the load test. EPIC fail at 88% loss. Put in a new battery and works fine.
Old Salt
autumnmass
Jul 2, 2015 10:35 PM
mhajek18
Jun 17, 2015 01:35 PM
Kv1ck
Jun 8, 2015 07:25 AM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
