Permanent Rear Window Solution
Old Dec 6, 2014 | 12:39 PM
klong's Avatar
Default Permanent Rear Window Solution
After fussing with Chrysler, NTSB, BBB, etc. for the past two years, gluing and sealing my window multiple times, having it "professionally done", etc., only to have it fall out while driving, I finally found a permanent solution: A picture is worth a 1000 words, right?
I took it to my local custom upholstery/boat cover guy (shameless plug here for Coachcraft Custom Upholstery, Fredericksburg VA - ask for Buck or Janice, his wife and mention my name - Kevin Long). If anyone wants larger pictures just let me know.
Coincidentally, I have a really dark tinted rear window - free to the first person to come and get it!
Kevin Long
Old Dec 6, 2014 | 12:44 PM
Da55id's Avatar
Default Re: Permanent Rear Window Solution
cool - what was the price? I live in Fairfax VA, and know I'll need this someday :-0
Old Dec 6, 2014 | 12:57 PM
klong's Avatar
$750 and well worth it!
Old Dec 6, 2014 | 12:58 PM
klong's Avatar
I should add that the rear defroster is disconnected: my car is garaged, almost never driven in the winter, and certainly not in inclement weather, so I have no need of a rear defrost - haven't used it since I bought my car in 2009.
Kevin
Old Dec 6, 2014 | 01:56 PM
Da55id's Avatar
THANKS!
Old Dec 6, 2014 | 02:50 PM
RED DOG's Avatar
Hi Kevin, I want to make sure I understand this . . . for $750.00 you had a plastic rear window sewn onto your top??
Old Dec 6, 2014 | 04:47 PM
Larry Hitze's Avatar
Is there any durability issue with his? Fading, discoloring?
Old Dec 6, 2014 | 09:51 PM
xjken's Avatar
Do you know if its water tight?
Old Dec 6, 2014 | 11:49 PM
Abaton6's Avatar
$750 seems a bit steep to me.
Old Dec 7, 2014 | 12:35 AM
Years ago I had a new window like that sewn into my jeep top. From time to time I had to use "Seam Seal" on the stitches. The stitches did wick water and leak if left alone.
Old Dec 7, 2014 | 08:43 AM
rustyscheuer's Avatar
I have a question: Has anyone found a way to "treat" a window surround that has not yet fallen out?? Like a glue etc. that can be applied to reinforce the adherence of the glass to the canvass??? Seems like if there was it might forgo the failure.
Rusty
Old Dec 7, 2014 | 09:12 AM
Da55id's Avatar
That's a really good idea! I'd pay up to $250 right now for a really effective preventive measure! Any ideas?..?
Rusty
Old Dec 7, 2014 | 09:40 AM
Da55id's Avatar
This seems highly recommended from other fora...
Amazon.com: 3M 08008 Black Super Weatherstrip Adhesive Tube - 5 oz.: Automotive Amazon.com: 3M 08008 Black Super Weatherstrip Adhesive Tube - 5 oz.: Automotive
Not sure if it could be a preventative though...
Old Dec 8, 2014 | 10:08 AM
klong's Avatar
So far it has been watertight; I had it done in June and wanted to make sure there were no issues before I posted anything.
Since then I've hand washed it several times, run it through an automatic car wash, and took it to one of the self service ones - I had about 10 -12 drops on the rear deck after that, but nothing else.
No fading, yellowing, etc. is evident, but I do keep it in the garage.
As for cost, that was the quoted price, probably because Buck had never done one before; he had to completely remove the top to sew the window in, and it was a lot cheaper than a new top.
Kevin
Old Dec 8, 2014 | 12:20 PM
xjken's Avatar
Good to know it's another option available. Like you I never drive mine in wet, frosty or snowy weather so I have no use for the defroster either. When mine fails it will probably depend on my financial situation at that time if I replace the whole top or go with this fix. Yesterday while coming home from lunch I was behind a VW Golf convertible that the rear window obviously had fallen out. There was an inch wide (maybe more) strip of clear silicon around the entire window. TACKY!
MiamiTVR
Jan 30, 2016 02:15 PM
Sep 13, 2015 02:12 AM
maxcichon
Sep 4, 2015 12:50 PM
d907ie
Aug 31, 2015 08:56 PM
sittininthesun
Aug 24, 2015 10:47 AM
