convertible top Actuator for Central Locking system
Old Oct 12, 2015 | 06:53 PM
Grey Blitz's Avatar
Red face convertible top Actuator for Central Locking system
Went to the Chrysler dealer today to have my convertible top checked. It doesn't open or close. I was told it is the Acutator for the Central locking system. A fairly small part in the Trunk lid. Repair cost 1500$. So I took it home but you can see where the dealer scratched off the part number so I wouldn't be able to see it. Any body can help me with this ?
Old Oct 12, 2015 | 07:15 PM
Grey Blitz's Avatar
Default Re: convertible top Actuator for Central Locking system
the other part is micro switch in the tonneau cover that opens the latch for the top. Don't know the name of that one. Part number?
Old Oct 12, 2015 | 07:35 PM
My suggestion is to call Klaus at Top Hydraulics ( 541.902.3214 ) and see if he can help you out.
http://www.tophydraulicsinc.com/en/
Old Oct 12, 2015 | 07:41 PM
Grey Blitz's Avatar
Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc
Thank you Ala_xfire
, I will try that. It's not a hydraulic part though.
Old Oct 12, 2015 | 07:48 PM
BOTH the tonneau and rear bow latches are hydraulic.
I think Klaus may also have some miscellaneous parts too, like the switches.
But, I could be wrong, and usually am.
Old Oct 12, 2015 | 07:59 PM
Grey Blitz's Avatar
Unfortunately Klaus could not help me. Hydraulics are OK.
thank you, called he is not there tonight but I will try again in the morning. Keep your fingers crossed.
Old Oct 12, 2015 | 11:39 PM
What was the number scratched from, the switch on your car?
Old Oct 12, 2015 | 11:57 PM
I suspect that it is not the Central Locking System but a part in the Hydraulic Control Unit.
Also you say the top does not open or close so it must be stuck halfway between opened and closed. True or not because will not open or close cannot be true.
Did they scratch a number off your car part or the estimate? One is malicious damage the other good business.
All the Chrysler part numbers for the convertible roof can be found in the 2005 Parts Manual (CLICK) in the Body Sheet Metal section.
Old Oct 13, 2015 | 01:44 PM
RED DOG's Avatar
If you can send me a photo of the part you're talking about I'll look at my car and get you the part number. RedDogNumber1@aol.com
Old Oct 19, 2015 | 05:17 PM
Grey Blitz's Avatar
Thank you all for the help.
I ended up bringing the car to the Chrysler dealer to find out what is wrong. Original diagnostic was central locking actuator and micro switch in the tonneau over latch. repair cost $ 1500. I picked the car up without having the repairs done. After further investigation the problem was solved. There is a spring in the lock of the tonneau cover. that springs seems to have worn out and did not spring back to make contact with the micro switch. After some search and additional help from members parts were found and the repair was completed for $100. The switch could not be found on eBay but we found a car with the parts still in it and removed them ourself. twisting and turning since the car was pretty mangled and the trunk could not be opened. I assume that switch is not being produced any longer since even Chrysler dealer would have to get one second hand.
Old Oct 19, 2015 | 05:20 PM
Grey Blitz's Avatar
Thank you for your help. Language problems...LOL. The top would not open when closed and would not close when open. I updated the results . thank you , thank you, thank you for the pdf file.
Osusannah
Feb 12, 2024 01:49 PM
Chachi66
Aug 16, 2021 04:24 PM
xfireon20z
Mar 15, 2016 04:28 PM
Ian69
U.K.
Jan 2, 2016 09:30 AM
Selbyl
Sep 26, 2015 04:15 AM
