Convertible top switch
Old Apr 27, 2016 | 06:33 AM
djohn14296's Avatar
Talking Convertible top switch
Ok, need to pick some one's brain or all your brains. I removed my 2 folding top hydraulic cylinders, yesterday. I have everything closed and buttoned up, except I can't lock the tonneau cover down until I get my new wrench. Will this cause my top button to flash on and off(only when the key in the run position), until the tonneau cover is locked. Is there some action I can take to stop its flashing until wrench arrives, such as a fuse removed maybe? Tape the 2 sensor connection on the 1 cylinder together? Any help greatly appreciated.
DJ
Old Apr 27, 2016 | 06:38 AM
Default Re: Convertable top switch
You can usually get a 10mm open end wrench thru the slot to lock the tonneau cover.
Old Apr 27, 2016 | 07:04 AM
djohn14296's Avatar
Trust me, I've already tried that, no go. I can live with the light blinking on and off for a short period of time. The more I think about it, I believe it has more to do with the 2 sensors on the one hydraulic cylinder as it wouldn't blink when the cylinder(s) were hooked up. I was opening an closing it manually then and not locking the tonneau cover then.
Old Apr 27, 2016 | 02:25 PM
Did you try grinding down the 10 mm to make it thinner?
Old Apr 27, 2016 | 02:28 PM
I didn't have to, mine was thin enough, but he could grind down a cheap one.
Old Apr 27, 2016 | 06:18 PM
djohn14296's Avatar
No, I've ordered one from ECS Tuning store. Don't have a bench grinder any more. I can wait.
DJ
Old Apr 29, 2016 | 10:47 PM
KDW4Him's Avatar
Default Re: Convertible top switch
DJ
The tonneau cover switch senses the not locked condition until you latch the 10mm down.
Old Apr 30, 2016 | 02:32 AM
djohn14296's Avatar
Thanks, just waiting on my service tool.
IndyFire
Apr 19, 2016 12:30 PM
ZERACER
Feb 24, 2016 10:10 AM
ZERACER
Feb 20, 2016 03:51 PM
WindRestrictor
Feb 19, 2016 11:20 PM
Rowdy20
Feb 14, 2016 10:09 PM
