Is Rear Camber Adjustment Possible?
Old Nov 8, 2016 | 05:43 PM
tleed's Avatar
Default Is Rear Camber Adjustment Possible?
I just put brand new tires on the rear of my 2005 Roadster. I had the inside of the right rear tire wear out a little early.
So I just tried to get it 4-wheel aligned. The shop tells me the right rear is out of camber & can't be aligned. No adjustment is available, they say, and they can't find any dealer or aftermarket parts to make it adjustable. Hmm. Oh, and I always have a slightly leftward turn on the steering wheel. Are these things related? And how do I get the rear end aligned? An earlier post mentioned "a set of $95 Speedway adjustable rear camber links", but I can't find them. What are they & where do you get time?
Thanks!
Thomas
Old Nov 8, 2016 | 05:49 PM
Default Re: Is Rear Camber Adjustment Possible?
Speedway Racing is holding them for you !
here's my post on it : https://www.crossfireforum.org/forum...ight-rear.html ( post # 14 )
And YES, this can make the car hunt to the left, mine always did until I installed the adj camber links and the technician was then able to get both camber and toe-in adjusted.
Old Nov 8, 2016 | 06:09 PM
Squirrel Crusher's Avatar
Ground Control thru NeedsWings corrected my problems. Squirrel Crusher
Old Nov 8, 2016 | 07:04 PM
tleed's Avatar
"Ground Control thru Needswings"? I have no idea what that means.
Are those name brands? Part names? Vendors? Manufacturers? The name of an air force managerial office?
Old Nov 8, 2016 | 08:40 PM
Steve Jr's Avatar
Needswings.com is sponsor of this forum and the place to turn to when you need parts and advice from a crossfire owner. Just call Rob. (Hope you don't mind the hipe!) .....
Old Sep 14, 2019 | 11:07 AM
rocketman109's Avatar
What is the rear camber specification after you install the camber kit ?
Old Sep 14, 2019 | 12:07 PM
Same as it was before. But most put that kit in for extra camber.
I know my first Crossfire Roadster had adjustable camber in back, it would eat a set of rear tires to steel in 20,000 miles or less - but MAN did it hold the road in the curves.
Old Sep 14, 2019 | 03:20 PM
zip439's Avatar
From service manual: rear camber -1 degree 8 minutes = -1.13 degrees; rear toe 1.2 degrees
Full spec in service manual section 2 page 12.
alignment shops will have all the data
Old Sep 14, 2019 | 03:36 PM
Ok, but what would have been the likely "performance setting" that the previous owner may have used on my car?
The car had the original tires on it when I bought it at 13,351 miles. Sometime in the early 20,000 mile range (I sold it at 28,xxxx) it had worn the inside tread on both rears down to steel cords.
I assume the guy put the arms in soon after purchase, but I do not know that for sure.
I had no idea it had adjustable camber until I realized the tires were worn so unevenly - the shop that put the tires on told me and suggested an alignment. But after checking with those here, I realized I had a perfomance mod. I had the alignment checked, the front was, I think, to spec - but I remember seeing a lot of red in the rear's readings. I wish I'd saved that page.
Old Sep 14, 2019 | 05:17 PM
zip439's Avatar
It is impossible to say Mark. What type of adjustable camber did the car have, bolts or adjustable arms like Ground Control. The two have different adjustable range. I made my own adjustable links for the rear of my limited.
20,000 miles isn't bad for the rear end, even with all season tires, it is quit good for summer tires.
The toe adjustment has as much to do with rear tire wear as camber!
Performance camber on the rear could be in the 2.5 to 3.0 range, anything more than that on tires you also use on the street is just wasting rubber and things like the sway bar, coil springs and unsprung weight start to play more into corning grip; it is a lot more than just camber. Type, brand, size, style of tire?
That's just my opinion, and it's worth about what you paid for it.
Old Sep 14, 2019 | 06:02 PM
A chart showing alignment.
Old Sep 14, 2019 | 09:14 PM
Originally Posted by tleed
"Ground Control thru Needswings……."?
Maj. Tom talks to Ground Control all the time…
