Door Locks
Old Aug 15, 2017 | 07:35 AM
mlange's Avatar
Default Door Locks
I own a 2005 Crossfire roadster. Recently the passenger door lock and the trunk lock stopped working. The drivers side door still works. Any ideas what mightbe causing this? I appreciate help you have with this!
Old Aug 15, 2017 | 08:35 AM
Default Re: Door Locks
Most likely a fractured air tube where it is flexed as the trunk is open/closed.
It will be inside the protective covering and can be repaired with a small section of proper sized rubber or plastic tubing ( think gas line for a lawn mower )
