windshield trim
Old Feb 1, 2021 | 09:13 AM
batmanmiami1's Avatar
Default windshield trim
Just wondering, has anyone had their windshield replaced ( roadster) without having to replace the windshield trim with new. I'm finding the price of a new windshield not that bad, but, the cost of replacement OEM trim is another matter.
Old Feb 1, 2021 | 09:51 AM
UrbanE's Avatar
Default Re: windshield trim
I’ve had my windshield replaced 3x never a problem with the trim
the tech removes all three pieces, windshield is replaced and the trim goes back on.
why are they telling you that the trim needs replacement. That would make it a really expensive windshield change out
Old Feb 1, 2021 | 10:10 AM
The reason they're telling me they need to replace the trim? - $284 for a Pilkington replacement windshield, (not that bad) $434 for new OEM trim. (Glass America). Nothing I need to do immediately just checking out prices.
Old Feb 1, 2021 | 11:11 AM
UrbanE's Avatar
Does your vehicle have existing trim around windshield?
what is the reason given to replace the trim? If your handy and going to get this done, I would strong suggest you remove the 3 piece of windshield trim before you take it to the glass shop.
Always keep in mind, no one cares about your car as much as you do.
good luck
Old Feb 1, 2021 | 12:51 PM
Ronman's Avatar
You are more likely to need the rubber windshield molding at the bottom changed, not the trim.
Old Feb 1, 2021 | 01:01 PM
Really wasn't buying the trim replacement story, never had to do it with other cars. Since I am relatively new to the Xfire just thought I ask what others had found. Now, if they had told me all the tires had to be rotated first, that I would have bought.
Old Feb 6, 2021 | 07:23 PM
lovecross's Avatar
I suggest finding a reputable/experienced glass tech/shop. I believe that the upper trim piece is prone to go "missing in action" if not reinstalled properly/securely and it may be hard to find a replacement.
Old Feb 14, 2021 | 09:00 PM
Goldwing's Avatar
Had mine replaced at Safelite a couple years ago. I asked that they use new double stick tape and also carefully examined the alignment. One piece was a little off and they adjusted it no problem. It has been fine since then.
Old Feb 15, 2021 | 06:26 PM
philosophico's Avatar
That glass shop trying to rip you off because you're an old man. The window trim pieces can remove safely without having to be replaced.
Old Feb 15, 2021 | 09:42 PM
Hilander's Avatar
I have an extra one. Call me 804-944-0001
Old Feb 16, 2021 | 09:17 AM
Hey! Less of the old man, I prefer vintage. 😉
Old Feb 17, 2021 | 08:09 PM
Two shots of Pfizer, it's good to be old. The more I think about it the less interested I am in replacing the windshield until it is absolutely positively necessary. Doesn't leak, trim stays in place during quick sprints into the 3 digit + speed zones. Think I can live with a few scratches for the time being..
Old Feb 20, 2021 | 05:57 AM
ardenian's Avatar
what thickness of double sided tape do you guys use to fix the windshield trim?
Old Feb 20, 2021 | 12:32 PM
zip439's Avatar
I measure 1.2 mm thick; 3M Auto Advanced super strength molding tape.
Old Feb 20, 2021 | 12:35 PM
zip439's Avatar
Don't know how I ended up with this double post??? Sorry
OUTLAW 101
Jan 31, 2021 08:00 AM
jonq67
Jun 6, 2017 11:26 AM
mbisaha
Feb 16, 2017 09:49 AM
huxbars
Oct 5, 2014 09:45 AM
kenreichert
Oct 22, 2013 07:25 PM
