Convertible top probllems
Old Jun 12, 2021 | 03:35 PM
Davidod's Avatar
Default Convertible top probllems
I just bought an 2007 Crossfire roadster. When it was delivered the driver’s door would not lock from the remote. The top was workings but the trunk will not open although it sounds like a solenoid is trying to put in. I put the top 1/2 way down and released the trunk latch. Hung the divider back up and put the top back up. Now I can’t get the top to go down or the trunk to open. Everything I’ve read is that it might be a micro switch but not being able to open the trunk or put the top down I’m unable to check anything. The fuses are all good. Any help would be appreciated. Thanks.
Old Jun 12, 2021 | 10:21 PM
Doc78's Avatar
Default Re: Convertible top probllems
Hello,
I will try to help you. Is the handle on the trunk loose as in moves but the trunk wont open or is the handle stiff as you cant move it?
Do you hear the pump running when you press the top button down?
https://www.crossfireforum.org/forum/crossfire-roadster/39283-trunklid-jammed-4.html#post614955
https://www.crossfireforum.org/forum...operation.html
https://www.crossfireforum.org/forum/crossfire-roadster/65891-rebuilding-convertible-top-hydraulic-system.html
These may help you.
Old Jun 12, 2021 | 11:49 PM
Davidod's Avatar
The handle was not stiff and I could hear the a sound in the trunk lid for the last two days. I looked at it again tonight and it started working . Finally got the trunk open . How long will it last? It looked like the divider was not hitting the micro switch on one side so I’ll try the top tomorrow. Hopefully that was the reason the top would not go down. The driver’s side door still will not lock with the remote but the passengers door works fine.
Osusannah
Feb 12, 2024 01:49 PM
Intimacy
Oct 15, 2017 01:48 PM
TopJimmy
Aug 7, 2017 09:16 PM
dennisoates
Oct 16, 2016 09:35 PM
deltacrossfirebob
Sep 20, 2016 06:05 AM
