How to replace D-ring that pulls down top?
Old Sep 7, 2023 | 09:26 PM
K3522's Avatar
Default How to replace D-ring that pulls down top?
I am installing replacement linkage and d-ring. The old d-ring and turning mechanism broken and so I had no problem taking the pin out of the old d-ring.
The new turning mechanism goes down in place and then there is no room to put the pin in the d-ring.
I will get pictures in the morning. It is too dark in the garage right now.
I do not understand how you can install the d-ring and then turn it clockwise to add the pin?
Old Sep 8, 2023 | 01:38 AM
JSK's Avatar
JSK
Default Re: How to replace D-ring that pulls down top?
I replaced the D ring and linkage on my blue roadster a little over a year ago, I don’t recall having any problems. I don’t even remember looking for any instructions. The only advice I can offer is step back, have a cold drink and start again. Seriously I don’t recall having any issues. Sorry I’m not any help, I will take a look in the morning and if any bells ring I’ll revisit.
Old Sep 8, 2023 | 08:34 AM
I don't see any reference to a 'pin'. Looks like the Release Handle is held on by something like a keyway and secured with a set screw - common practice for that type of mounting. Above page from the Service Manual makes it look fairly simple to replace the Release Handle. Did you rotate the new Release Handle clockwise after you installed it on the top's linkage? Without doing that, I could see that the location for the set screw would be near impossible to get at.
Old Sep 8, 2023 | 08:36 AM
K3522's Avatar
Didn’t sleep well. Then at 5:30 am I got an idea looking at the service manual page again and went out in the garage and put the d-ring up to the mechanism and pushed up hard and turned like the dowel pin was in and that exposed the opening for the pin and it lined up because I was pushing up like the the handle would be if the pin was already in. Volia!
Old Sep 8, 2023 | 08:44 AM
Originally Posted by K3522
Didn’t sleep well. Then at 5:30 am I got an idea looking at the service manual page again and went out in the garage and put the d-ring up to the mechanism and push up hard and turned like the pin was in and the exposed the opening for the pin ant it was lined up because I was pushing up like the the handle would if the pin was already in. Volia!
You might know that the Service Manual didn't say anything about pushing the Release Handle up. Probably required to engage the keyway. Makes sense for that step so the keyway rotated with the Release Handle when you turned it. Glad this worked out for you.
Later
JSK
Mar 18, 2017 01:34 PM
king happy
Oct 25, 2016 05:13 PM
RaxCrossfire
Sep 5, 2012 10:26 PM
cts5039
Nov 13, 2009 11:57 AM
davelyoung1
Feb 22, 2007 05:06 PM
