Key & Starting
Old Feb 19, 2006 | 01:49 AM
HDDP's Avatar
Default Re: Key & Starting
Originally Posted by bobs
What I did find amusing is the description they give of the starting system:
An electrically operated engine starting system is standard factory-installed equipment on this model. The starting system is designed to provide the vehicle operator with a convenient, efficient and reliable means of cranking and starting the internal combustion engine used to power the vehicle and all of its accessory systems from within the safe and secure confines of the passenger compartment. See the owner’s manual in the vehicle glove box for more information and instructions on the recommended use and operation of the factory-installed starting system.
Like there's any other way to do it!
Hey BOBS: gimme a break, I've been bump starting the car for the past two years... You mean there's a starter ? Darn, my girlfriend is going to be happy about this, she won't have to push it anymore...
Old Feb 19, 2006 | 06:40 AM
bobs's Avatar
Yep! And she probably won't need to wear those Nomex boots & full face helmet when you guys go out anymore either!
Old Feb 25, 2006 | 04:42 PM
Rotten's Avatar
I noticed it also on mine a while back. How bad is it going to fry the battery, wiring and starter when one fails to start?
Old Feb 26, 2006 | 12:22 PM
BullFrog's Avatar
it happened when my mercedes' fuel pump went bad the car was auto cranking and it wouldn't stop i had to pull the key out forcibly or i would've fried either the starter or killed the battery.
REYMARTZ
22
Aug 7, 2021 12:37 PM
jhansen
21
Feb 15, 2017 04:26 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
gtjl
17
Jul 22, 2015 06:28 PM
TOPLA
Jul 14, 2015 07:46 AM
