Engine Missing (dead spot)??
Old May 21, 2007 | 11:18 PM
huperoptik's Avatar
Question Engine Missing (dead spot)??
I am the owner of a brand new SRT6 roadster with a little less than 400 miles on it. The car seems to be missing or cutting out in 1st gear when the RPM's are between 1,000 - 2,500. Has anybody had this issue?
Old May 21, 2007 | 11:49 PM
nox1s's Avatar
Default Re: Engine Missing (dead spot)??
Try this thread ~ https://www.crossfireforum.org/forum...tercooler+pump
(I have no idea though, just throwing ideas on there)
Old May 22, 2007 | 01:10 AM
huperoptik's Avatar
Thanks for the link, but there is nothing there like I am talking about. It has plenty of power, it just cuts out or misses for a second and then its back running strong. Anybody else have any ideas??
Old May 22, 2007 | 01:46 AM
xbcyrus's Avatar
when this occurs, the supercharger is just overheating and it needs to cool down, so don't give the car a lot of gas when you notice this. give it a few minutes to cool down and your good, or just put your car in neutral for 20 seconds or turn the car off then back on that worked for me.
Old May 22, 2007 | 06:40 AM
crossfirefun's Avatar
have you tried the throttle reset trick?
https://www.crossfireforum.org/forum...ad.php?t=15638
Old May 22, 2007 | 12:38 PM
msheredy's Avatar
I think what you are experiencing is the supercharger clutch engaging. Do you sometimes hear a slight chirp too? Many E55 and some SLK/C32 owners experience this. I too experience it. You can read through my experience here. Here is a thread from an MB forum where they are saying that if you are experiencing a rough engagement that the clutch needs to be replaced. Now that I have found out this info I want to take mine back in and tell them what I have found.
On my thread only the 1st and last page really explain what I was experiencing and the outcome.
Old May 22, 2007 | 01:54 PM
distantpulse's Avatar
Mine has this miss in the morning when I first start it and try to move forward. The car hesitates a bit almost like it wants to stall, but then after it warms up its fine. Any ideas to what that could be?? Just cold maybe? Hmm...Never had a newer car do this.
Old May 22, 2007 | 11:53 PM
huperoptik's Avatar
I have not tried the throttle reset trick yet. When I have a minute this weekend, I will try it. Can't hurt.
I will also read the MB forum when I have a chance.
This car also sputters a bit when you first take off in it, but when it warms up that goes away. Just seems like it is cold blooded. But the cut-out or hesitation between 1,000 - 2,500 RPM's does not go away after warmed up.
Thanks for your help so far.
Old Aug 6, 2007 | 12:02 PM
cgocifer's Avatar
This is exactly what I'm experiencing, chirp and all. My thread is "Lurch" where I discuss this problem. Anyone confirm the replacement of the S/C clutch? Why would it go bad on a car with less than 12k miles?
Old Aug 6, 2007 | 01:30 PM
vegassrt's Avatar
I have the same thing as distantpulse...I posted a thread on it a couple weeks ago...the car hesitates and seems like it is going to stall the first time I accelerate after a cold start...once I accelerate 2 or 3 times there is no more hesitation...the car is at the Chrysler dealership as we speak...I'm starting to wonder if this is just another quirk with these cars...
Old Aug 6, 2007 | 01:32 PM
AMGLover's Avatar
Message Deleted
Old Aug 6, 2007 | 01:43 PM
cgocifer's Avatar
Any updates on your situation? Mine and a few others on here have the exact same thing you are talking about. Everything seems to be pointing to the supercharger clutch engaging (normal) or failing (abnormal). I hear a tiny little chirp at the same time when I have the windows down.
Old Aug 6, 2007 | 02:07 PM
NeverEnough's Avatar
I assume this is normal. My 15,000 mile car does it too. I think it actually has to do with the Drive-by wire throttle. I reset the throttle memory and it went a way for about a hour, then came back. I wonder if the Sprint Booster would fix this. It could also be the SC Clutch I guess, but I've never heard any kind of chirp associated with it. I know it only does it under light throttle input. If you give a fair amount of go pedal, it doesn't do it.
Old Aug 6, 2007 | 02:13 PM
cgocifer's Avatar
I'm pretty sure it still does it with more go pedal application; however, it happens so quickly, it is barely noticeable. Actually, when accelerating quickly, I don't even notice it unless I am looking for it. Accelerating slowly however, is a different story. Very noticeable and yes, I hear a little chirp when the windows are down.
Old Aug 6, 2007 | 03:50 PM
AMGLover's Avatar
Message Deleted
Old Aug 7, 2007 | 12:23 AM
DAMSRT-6's Avatar
Hey guys, I can attest to having this same "tug" feeling in manual mode. First gear at 2,900 RPM every time. A friend of mine is getting his SRT-6 (30 miles on it) at the end of this week. It will be interesting to see if his has the same issue.
Old Aug 7, 2007 | 02:12 AM
Brent's Avatar
When my supercharger clutch was failing/failed I did not notice any chirp or surge. Then again there are times I wouldn't even notice Hooter Girls performing a dance act on the hood of my car. My supercharger clutch failed at around 8,000 miles.
Old Aug 8, 2007 | 07:00 PM
vegassrt's Avatar
As suspected, the Chrysler dealership said they can't replicate the problem...
xfClifford
Mar 3, 2021 04:52 PM
waldig
Sep 2, 2015 11:02 AM
Mopar or No Car
Aug 11, 2015 08:11 AM
axnguyen
Jul 21, 2015 11:41 AM
Rusty475
Jul 13, 2015 10:03 AM
