ASP Pulley Review
Old Oct 26, 2007 | 03:56 PM
distantpulse's Avatar
Default Re: ASP Pulley Review
I really hope you get low 12's out of it. I was going to say a conservative 12.5's at 111-112, but i hope you're right! I am definitely considering these two mods! Can't wait for the results!
Old Oct 26, 2007 | 04:32 PM
ShawnQ's Avatar
More traction will be needed before long.
I'd look at getting that limited slip and cut some better 60's.
SQ
Old Oct 26, 2007 | 04:34 PM
Chi-Town SRT/6's Avatar
sweet, sounds like your soon to be worlds quickest/fastest srt6.
I think there is a guy with a Renntech car who runs 12.1-12.2 somewhere out there...
Old Oct 26, 2007 | 04:35 PM
SQ
Agreed...I wish they made a DR in 19 inch! Maybe some regular crossfire 18's on back with DR's?
Old Oct 26, 2007 | 04:37 PM
ShawnQ's Avatar
I think I have heard/seen that before as well.
Either way, you'll be beating up on stock Z06's!
I wonder why my mph was so high on my best run...if you could repeat whatever I did (or didn't do), you would be faster yet. I'm not sure what I did differently though that gave me 3 more mph.
SQ
Old Oct 26, 2007 | 04:42 PM
SQ
Byron dragway is known for low trap speeds (2-3 mph) On one of my runs I hit 109.2 but ran a 13.0.
I think I can come close to 115 for a trap speed now but we shall see!
Old Oct 26, 2007 | 07:35 PM
SRTpowa's Avatar
As I stated in another thread:
ASA lists the FN1, which I believe is the same a the ZR2 that tire rack carries, in a 18x10 with a 25 mm offset, slap some 295/35 BFG's, or even better 305/35 Mickey Thompson, and I think your traction problems will be solved. They are probably about $300 a pc then throw in the tires your looking around $1,200.
Old Oct 26, 2007 | 07:46 PM
NeverEnough's Avatar
I'll make a BOLD prediction and guess i'll run a 12.3@115 plus...
BOLD? Yah think? I'm gonna guess 12.5 @ 112.
Old Oct 26, 2007 | 07:49 PM
I'd be happy with that...I just think the seat of the pants feel is A LOT faster than my Z06 which ran a 12.6. I'm planning on going sunday so we shall see...you been back to the track with yours yet?
Old Oct 26, 2007 | 07:50 PM
I'm also wondering what kinda power this tranny can handle without any problems...
Old Oct 26, 2007 | 08:11 PM
I'd be happy with that...I just think the seat of the pants feel is ALOT faster than my Z06 which ran a 12.6. I'm planning on going sunday so we shall see...you been back to the track with yours yet?
I just put the intake on today and I can't float down the track. It has literally rained 7 inches in 4 days and its still coming down. The tracks in my area are shutting down for the season, so I may not be able to get to the track again before spring.
Old Oct 26, 2007 | 08:44 PM
+fireamx's Avatar
I'm not the kind of guy to say I told you so, but I've been trying to get somebody to use the front wheels on the back (at the drags)
for years, just to take advantage of the 1" smaller tire height.
But with your cars additional power, using BFG Drag Radials, as wide as the front wheel width will accept should be the ticket.
With a 24.5" tall tire, your cars 3.07 rear end should feel more like a 3.27. But if the Limited uses the same differential as the SRT (with a different ratio) you might be ahead of the game if you pick up a differential at a salvage yard from a limited, to install your new "posi" unit in. Then it would pull more like you had a 3.45 gears.
I'd love to see you get your car into Viper territory.
Old Oct 27, 2007 | 09:49 AM
I think it's already there...not the NEW viper territory but definitely old viper territory...going to the track tomorrow so we shall see!
Old Oct 27, 2007 | 03:51 PM
Pins & Needles!!!
ARE YOU THERE YET? ARE YOU THEE YET? ARE YOU THERE YET?...
Old Oct 27, 2007 | 04:02 PM
Pins & Needles!!!
Haha nope not yet...Bright and early tomorrow.
Just for kicks I went down this road that has a speed limit sign maybe 100 yards up from a stop sign...I used to floor the Z06 and check my speed when I passed the sign...the Z06 would be at 60 mph by the time I went past the sign...I did it in the SRT today twice and both times between 70-75 mph! I am getting very excited myself!
Old Oct 27, 2007 | 08:00 PM
BlUEMDsrt6's Avatar
Wow, good job with the mods. I was in bliss just installing the sprint booster. Now you got me thinking bigger.
Old Oct 27, 2007 | 08:41 PM
SRTpowa's Avatar
Just had a thought, with the intake and pulley, is the stock ECU capable of adding enough fuel? Any chance you could be running dangerously lean, causing the large power increase you are experiencing, but possibly hurting your motor?
Old Oct 27, 2007 | 08:50 PM
  #38 (permalink)
Maybe...but it still retains the stock belt so I doubt it...this benz ecu seems pretty doggone good to me. It has adjusted perfectly to the pulley and intake. My times tomorrow hopefully live up to all the hype I have caused.
Old Oct 27, 2007 | 08:56 PM
  #39 (permalink)
SRTpowa's Avatar
True. I'm sure if it was running too lean it would be smart enough to pull timing. I'd be curious to see what your A/F ratio is at on the dyno. Maybe you can make that happen? Good luck tomorrow! Make us proud.
Old Oct 27, 2007 | 09:10 PM
  #40 (permalink)
It's supposed to be high 30s low 40's tomorrow during my first run...we all know how much harder these cars pull in the cold. Hopefully the track is sticky and I can make the SRT gang proud!
