SL55 Y-Pipe Installed
Old Apr 4, 2008 | 11:47 PM
svo's Avatar
svo
Default Re: SL55 Y-Pipe Installed
I thought i rmemeber seeing dyno numbers on this somewhere - anyone have them?
Old Apr 5, 2008 | 04:35 AM
waldig's Avatar
Smile Re: SL55 Y-Pipe Installed
For anyone considering the addition of a better inlet, I would suggest that you try this no cost test.
I removed the wye pipe and made a short run around the area, came home and cut a check for the needswings inlet. With 'no restriction' without the wye AS A TEST FOR A SHORT TIME you will get the wooly bully feel of what is available by reducing the inlet restriction.
My dyno and 60 times are testament to the better breathing I now have with the needwsings, gasket matching of intake and heads, and the muffler delete. It is an warm air engine and the more air that you can heat the more horsepower youll get. Woody
Old Apr 5, 2008 | 08:25 AM
BrianBrave's Avatar
<--- Huge Horsepower
Woody - Glad you like your NW - The stock SRT6 Y-pipe is a weak point in the intake - that's why many have switched to the SL55 Y-pipe
Could you take a few pic's of the 90 deg piece that goes thru the radiator opening? Remove your grill and filter and post a few pics. Can you take a measurement of the ID for this piece.
Something like this
SL55 right side intake opening -
https://www.crossfireforum.org/galle...5/ppuser/14230
SL55 left side intake opening -
https://www.crossfireforum.org/gallery/showphoto.php?photo=13247
Old Apr 5, 2008 | 05:22 PM
McCombcliff's Avatar
I was interested in this until I saw these dyno results on the MB site...Can anyone explain the hp loss with this mod?
Run # 1 - WITH SL55 Y-Pipe (004.drf)
274.45hp / 284.13tq
Run # 2 - WITH SL55 Y-Pipe (005.drf)
273.47hp / 282.60tq
Run # 3 - W/OUT SL55 Y-Pipe, stock (007.drf)
283.29hp / 289.30tq
Run # 4 - W/OUT SL55 Y-Pipe, stock (008.drf)
280.77hp / 283.83tq
Old Apr 11, 2009 | 08:50 PM
ACRucrazy's Avatar
274.45hp / 284.13tq
273.47hp / 282.60tq
283.29hp / 289.30tq
280.77hp / 283.83tq
Was there ever an explanation to this?
Old Apr 11, 2009 | 09:24 PM
BrianBrave's Avatar
Do you have any idea?
Old Apr 12, 2009 | 05:56 AM
waldig's Avatar
Talking Re: SL55 Y-Pipe Installed
Standing waves due to a resonance issue? Velocity versus dimensions allowing a reversion effect to stifle the incoming air mass is my thought. Woody YOu know the old pipe organ effect length and diameter matter...
BTW Rob has revised the inlet design and is 3" on the passenger side, 2.5 or 2.75 on the driver side, ask him direct or he may come on and clarify the issue. He has recreated my "ebay elbows and water bed vinyl glued wye" in silicone to make a full sized cross section WYE assembly.
WW
Old Aug 6, 2013 | 03:35 PM
blackpepper's Avatar
After checking several sites,I still cant locate a sl55 y pipe,if someone who has a y pipe send me the number to the company becuase web addresses bring up tons of companys that are mostlys just salvage yards.
Old Aug 6, 2013 | 07:03 PM
DTMenace's Avatar
blackpepper
Here you go, Mercedes Benz AMG part# A 113 094 01 03. The inside diameter is 3 inches. This will not fit directly onto the stock air boxes (where the filters are located), they need to be reduced in size.
Dennis
DTMenace
Old Aug 6, 2013 | 08:02 PM
Gotcha going to a benz dealership tomorrow an pick one up thanks.
55chevy
Jul 22, 2024 02:31 PM
UNDER PSI
Nov 1, 2015 09:39 PM
ozkancab
Sep 25, 2015 10:55 AM
bbsrt6
Sep 19, 2015 11:21 AM
RacerXofFL
Sep 15, 2015 05:00 PM
