LET Motorsports
Old Nov 19, 2007 | 09:54 AM
Bulldogger's Avatar
Default LET Motorsports
After calling around for pulley sets, I decided to use LET. Erick is a great guy who answers the phone everytime you call and answers all your questions. The best part is if he doesn't know something he states "good question I don't know, but I'll find out". His pulleys are a little more money but they are a fluid balanced design vs a hard rubber dampener design of the factory one, which should eliminate the potential problem of the rubber dampener falling out and causing a misfire code. After considering my three choices of 178/181/185, I chose the 181.
Old Nov 19, 2007 | 10:38 AM
Haywood's Avatar
Default Re: LET Motorsports
What were your reasons for the 181? What are the biggest differences between the 3? Pully virgin wants to know! Thanks.
Old Nov 19, 2007 | 11:35 AM
Bulldogger's Avatar
Haywood, 178=3lb boost 181=5lb boost and 185=7lb boost. 185 will require ECU remap and puts the ECU outside of it capabilities in stock form. 178/181 will run within ECU capability and you can reprogram ECU at a later time for optimum HP/TQ. You can still run the 185 it's just that the ECU will start to retard timing to correct for that much additional air. I hope that made sense.
Old Nov 19, 2007 | 11:56 AM
Sidez's Avatar
hm.. wondering how needswings intake + plus 185mm pulley + an ecu tune would work out...
Old Nov 19, 2007 | 11:58 AM
BrianBrave's Avatar
<--- Huge Horsepower
Correct - but only above 5000 rpm. (per Erich)
Still - you will need to tune with the 185 pulley installed
I will let you know how the 185mm pulley + ECU tune + sl55 intake works out
Old Nov 19, 2007 | 01:08 PM
Bulldogger's Avatar
BrianBrave, are you going with the complete SL55 set-up? I though someone said the bigger air boxes don't fit on the SRT cars, at least that was the last info I got from the search.
Old Nov 19, 2007 | 02:20 PM
Sidez's Avatar
why not go with the needswings intake?
Old Nov 19, 2007 | 03:43 PM
BrianBrave's Avatar
Not true - just need a small adjustment to make em' work and feed all the air you could need.
To expensive and I don't like the look - and if I did I could make my own for less with off-the-shelf parts and the local powdercoater. Lots of threads on this forum on that.
xfClifford
Mar 3, 2021 04:52 PM
Jul 16, 2015 08:35 PM
RacingGoddess
Racing
Sep 18, 2009 10:31 AM
SRT SIX
Racing
Dec 2, 2007 12:27 AM
HDDP
Racing
Mar 13, 2007 06:20 PM
