LETMotorsports Now Carrying JOHNSON PUMPS!!! CM30!!!
Old Dec 10, 2007 | 08:41 PM
1FASTC32's Avatar
Default LETMotorsports Now Carrying JOHNSON PUMPS!!! CM30!!!
we just struck a deal with Johnson pumps and will have a our first shipment coming in this next week!
These are the specs...same pump i am running on my car!
Part Number 10-24504-03
Flow 6.9 GPM
Volts 12
Price: $120 shipped
These will be up on the website shortly for order!
There will also be a price break if this is ordered with one of our heat exchangers!
please let me know if you have any questions!
Old Dec 10, 2007 | 08:59 PM
SRTpowa's Avatar
Default Re: LETMotorsports Now Carrying JOHNSON PUMPS!!! CM30!!!
Dang, guess I jumped the gun. Bought mine a couple weeks ago from some place else. Sorry.
Old Dec 10, 2007 | 10:02 PM
1FASTC32's Avatar
no worries, just trying to let everyone know that we will be stocking these from now on...
Old Dec 11, 2007 | 04:55 AM
Sidez's Avatar
thats awesome are they also direct fits? or still require modifications?
Old Dec 13, 2007 | 12:43 PM
SRT6-Man's Avatar
Do we have to modify the pump or is it going to be plug n play?
Old Dec 13, 2007 | 12:52 PM
1FASTC32's Avatar
the only thing that you will have to modify is the wiring if you want the pump the way that it comes from Johnson...if not, we are going to create a direct plug and play harness so that you do not have to splice into your wiring harness...there will be a small fee for the direct harness...
please let me know if you have any other questions...
Old Dec 13, 2007 | 01:21 PM
Sidez's Avatar
when the stock fails this is the way to go.. no questions about that...
Old Dec 13, 2007 | 01:57 PM
AMGrasoul's Avatar
Isn't there a more powerful one? The CM90 I believe? Would be ideal for those of us with larger heat exchangers...
Do you carry this one or is the CM30 the one I'm thinking of after all?
Old Dec 13, 2007 | 06:06 PM
cudaman's Avatar
Subscribing for updates.
Old Dec 14, 2007 | 06:17 PM
HDDP's Avatar
Well it's about time you started posting here Eric... Give me the specs on your heat exchanger...
Old Dec 19, 2007 | 09:30 AM
amg-jerry's Avatar
The CM30 flows the correct amount of fluid over the HE. The CM90 seems to flow too fast and the fluid doesn't have enough time to cool. This is my opinion of course.
Old Dec 19, 2007 | 10:04 AM
HDDP's Avatar
Well, you opinion is correct... 7gpm is ideal for the OEM system up to 400 hp... This is per Gerhard Schruff at Bell Intercoolers...
Old Dec 19, 2007 | 10:57 AM
AMGrasoul's Avatar
key words... "larger heat exchangers"
That's why I was asking.
Old Dec 19, 2007 | 11:41 AM
HDDP's Avatar
Larger HE and seperate cooling system instead of the OEM shared system... Also insulation of the IC from the engine heat...
Old Dec 19, 2007 | 01:00 PM
1FASTC32's Avatar
the CM90 is still too much even with a larger heat exchanger...the idea behind what we have done with the upgraded heat exchanger and CM30 pump is to optimize the cooling efficiency of the system...if you flow more liquid than you can cool, you are defeating the purpose of the system...
Old Feb 17, 2008 | 09:09 AM
cgocifer's Avatar
Flow 6.9 GPM
Volts 12
Price: $120 shipped
Do you have the plug and play harness avail. yet?
Old Feb 18, 2008 | 05:47 AM
amg-jerry's Avatar
No, the needed adapter is locked by the manuf. and will not be sold to the public.
There isn't another cost friendly solution at the moment.
Old Feb 18, 2008 | 06:12 AM
HDDP's Avatar
Arrow Re: LETMotorsports Now Carrying JOHNSON PUMPS!!! CM30!!!
The connector is made by TYCO and available online. I'm away from home working, otherwise I could give you the part number...
Old Feb 18, 2008 | 06:25 AM
amg-jerry's Avatar
Correct, but Tyco (manuf.) isn't selling it.
This is from Tyco....I had about 20 email replies to her. Of course we don't need coding A.
For the mate: If you need cod A, the PN is 7-967570-3 There are no cod
B, C, or Z parts released for neutral sales.
Best Regards
Laura
Laura E. Turns-Thomas
Product Specialist
Tyco Electronics
Technical Support
Phone: 800-522-6752 / 717-986-7777
Fax: 717-986-7575
Email: product.info@tycoelectronics.com
Old Feb 18, 2008 | 06:55 AM
mrphotoman's Avatar
Can I see a photo of the pump? This may work on my car as well.
