“b” Schedule Maintenance Service
Old Feb 25, 2008 | 12:51 PM
huudoo's Avatar
Default “b” Schedule Maintenance Service
getting ready to take in to do B service
just wondering what most people pay for this .
i will take the oil and filter in . LABOR $11.80 + tax
rotate tires: $12.95+ tax...
reset FSS free
i dont think i need a cab filter yet, should be optional
SCOPE OF WORK FOR “B” SCHEDULE MAINTENANCE SERVICE
Oil Change
² Change oil and replace filter
Maintenance
² Rotate tires
² Replace dust filter
² Lubricate hood hinges, latch, and secondary latch
² Reset FSS Display
Function Check
² Horn, hazard warning flashers, turn signals, and indicator lamps
² Headlamps and exterior lighting
² Windshield wipers and washer system
² Check seat belts for damage and proper function
² Test hydraulic brakes and check parking brake function
Inspection
² Check front and rear brake pads for lining thickness
² Check condition of front and rear brake discs
² Check tires for damage and general condition
² Check tire inflation pressures and correct if necessary
² Check major underbody components for leakage or damage (if there are signs of leakage, determine cause
and repair)
² Check condition of front axle ball joints and rubber boots
² Check condition of steering components and rubber boots
² Check underhood components for leakage or damage (if there are signs of leakage determine cause and repair)
² Check condition of accessory drive belt
² Check headlamp aiming, adjust if necessary
² Check windshield wiper blades, replace if necessary
Fluid Levels
Check fluid levels for the following systems and correct if necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
² Engine cooling system (check corrosion inhibitor/antifreeze)
² Hydraulic brake system
² Power steering system
² Windshield washer system
Old Feb 25, 2008 | 01:25 PM
Default Re: “b” Schedule Maintenance Service
What mileage does the “B” SCHEDULE MAINTENANCE SERVICE appear or does it vary from driving condition's.
I got my Crossfire last April with 17,220 miles and have driven it 10,000 miles with no scheduled B yet appearing
Old Feb 25, 2008 | 02:31 PM
huudoo's Avatar
good catch VALKRYDERGUY
good answer / reminder, i forgot their is a indicator for that ...2 wrenches
i was thinking it was like 10.000 miles ..... do the 2 wrenches have to be on for the dealer to check / do B service ....
i was looking for a paper trail documentation, so later if some warranty work is needed ,they cannot say you never had the car in for service a or b
Valk
Jun 22, 2025 09:15 PM
UNDER PSI
Nov 1, 2015 09:39 PM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Abaton6
Sep 24, 2015 10:14 PM
