Engine miss after installing cold air intake?
Old Mar 7, 2008 | 06:36 PM
waldig's Avatar
Red face Engine miss after installing cold air intake?
I got the needswings installed and a set of LET phenolic spacer gaskets. After starting I had a big miss that was limiting power driving around the block. Pulled the intake and gaskets, searched everything, hoses, clamps connectors and found nothing absolutely nothing wrong or out of place.
Started it up and it ran fine???????? THe intake was torqued carefully both times, I am really scratching my head. The Engine check light came on the first time and did not go away after the car began to run better the second try?
How do I get the codes to better understand this ? The supercharger was working both times and was audiable so that was not involved as I see it.
Everything looks great and runs fine now but I wanna get smarter about this if possible. Thanks.
3/9/08 update:
After driving the car 4 short trips the CHECK ENGINE light reset and everything is right as rain.
Old Mar 7, 2008 | 08:18 PM
apkano's Avatar
Life is random...so am I.
Default Re: Engine miss after installing cold air intake?
I'm no genius on these computer controlled cars..(gimme a 440 with a carburetor and I'll make it sing a song!)....but if it were me.........i'd clear the codes by pulling the battery cable for a few, do a throttle reset, and see how it goes.
I think maybe your MAF has been reading one thing for quite a while....now you're really running some air past it and it got a little confused. The Mercedes software probably needs a little time to "learn" it's new environment.
Maybe even run it for a little while.....as I understand....the CEL, once triggered, can take a few cycles to reset itself.
Old Mar 7, 2008 | 08:27 PM
Moparrbust's Avatar
MAFs don't exist on MOST Diamler Chrysler vehicles....................speed density systems are used.
Old Mar 7, 2008 | 08:47 PM
apkano's Avatar
MAFs don't exist on Diamler Chrysler vehicles....................speed density systems are used.
WOW.....really?
Then please explain to me what cavity 11 of the PCM connector is for. Or possibly what they put all of this in the service manual for?
9 - 8 ENGINE - ELECTRICAL DIAGNOSTICS
ZH
(P0101) MAF SENSOR PERFORMANCE
When Monitored and Set Condition
²
When Monitored: With the engine running and no fault in the throttle valve actuator.
²
Set Condition: The Mass Air Flow (MAF) Sensor value is less than 16 kg/h when the throttle valve angle
is greater than 14° for approximately 5 seconds, or the MAF Sensor reading is greater than a calculated
value that is determined by engine speed and throttle valve angle for approximately 5 seconds.
POSSIBLE CAUSES
FUSED ENGINE CONTROL RELAY OUTPUT CIRCUIT OPEN
FUSED ENGINE CONTROL RELAY OUTPUT CIRCUIT SHORTED TO GROUND
SENSOR GROUND CIRCUIT OPEN
MASS AIR FLOW SENSOR SIGNAL CIRCUIT OPEN
MASS AIR FLOW SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
5-VOLT SUPPLY CIRCUIT OPEN
5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
POWERTRAIN CONTROL MODULE
Diagnostic Test
1.
CHECK FOR CURRENT DTC
Turn the ignition on.
With the DRB III
T, read the PCM DTCs.
Is this DTC present?
Yes
>> For complete diagnosis of this DTC, refer to (P0102) MASS
AIR FLOW CIRCUIT.
No
>> Go To 2
2.
INTERMITTENT WIRING AND CONNECTORS
The conditions necessary to set this DTC are not present at this time.
Note: Check connectors — Clean/repair as necessary. Poor pin to terminal
connections can set DTCs.Using the wiring diagram/schematic
as a guide, inspect the wiring and connectors specific to this DTC.
Wiggle the wires while checking for shorts and open circuits.
Note: Check for any Technical Service Bulletins that may apply.
Were there any problems found?
Yes
>> Repair as necessary.
Perform POWERTRAIN VERIFICATION TEST - VER 2.
No
>> The condition that caused this DTC to set is currently
not present. Inspect the related wiring harness for a
possible intermittent condition.
ZH
ENGINE - ELECTRICAL DIAGNOSTICS 9 - 9
(P0101) MAF SENSOR PERFORMANCE — CONTINUED
9 - 10 ENGINE - ELECTRICAL DIAGNOSTICS
ZH
(P0102) MASS AIR FLOW CIRCUIT
Old Mar 7, 2008 | 09:34 PM
NeverEnough's Avatar
Another possibility would be the phenolic spacers were leaking... I bad intake manifold gasket can cause a similar issue on none boosted cars...
Old Mar 7, 2008 | 10:05 PM
Brent's Avatar
Really can't help you other than to report that my car ran fine after installing the Needswings intake.
Old Mar 8, 2008 | 04:35 AM
amg-jerry's Avatar
Sent you an email Woody.
The 3.2L Kompressor uses a MAP sensor with a MAF simulator. The non Kompressor cars are MAF based....at least on the MB side.
If the car is running fine now, all that you should need to do is clear the code from the first part of the install.
Call me if you need help.
Old Mar 8, 2008 | 07:11 AM
Moparrbust's Avatar
WOW.....really?
[/LEFT]
Interesting.............I guess the non SRT N/A benz engines actually have MAFs. I; like many on this forum, have removed my entire intake and never saw a MAF. I will change my prior statement to...........damn near all Chrysler/Dodge built engines don't have MAFs..........they use speed density system.
Old Mar 8, 2008 | 09:41 AM
240M3SRT's Avatar
Also sounds to me like a leaking phenolic spacer may have been the issue. Because upon your reinstall it ran fine.
Old Mar 8, 2008 | 04:31 PM
tttosrt6's Avatar
the crossfire never had a Chrysler/Dodge built engine in it, SRT or not they are 90% MB and that's why they have MAFs and are faster then any other chrysler built car with just a 3.2l engine
Old Mar 10, 2008 | 08:40 AM
240M3SRT's Avatar
really? where is the srt6 MAF sensor located?
IGot2P
Jul 26, 2025 12:40 PM
Kodebuster
Nov 5, 2020 04:06 PM
4drturbo
Jan 3, 2019 02:46 PM
reiji
Oct 15, 2015 10:50 PM
Rusty475
Jul 13, 2015 10:03 AM
