Re: Engine miss after installing cold air intake?
Sent you an email Woody.
The 3.2L Kompressor uses a MAP sensor with a MAF simulator. The non Kompressor cars are MAF based....at least on the MB side.
If the car is running fine now, all that you should need to do is clear the code from the first part of the install.
Call me if you need help.
