Compatible Parts SLK32/SRT-6 CF
Old Jul 17, 2008 | 11:27 AM
BiGDSLK32AMG's Avatar
Default Compatible Parts SLK32/SRT-6 CF
Hi,
I was wondering what aftermarket engine modification parts are out there that you guys have experience with on your SRT-6's and what would be compatible with my SLK32AMG (most things). Any input is appreciated...
TIA
Old Jul 17, 2008 | 11:49 AM
Maxwell's Avatar
Default Re: Compatible Parts SLK32/SRT-6 CF
tvt designs has just about all the neccessary goodies you need.
Old Jul 17, 2008 | 12:02 PM
crossfirefun's Avatar
Welcome to the forum. if you look around in here you should find most of the stuff we have available.
https://www.crossfireforum.org/forum...play.php?f=103
Old Jul 17, 2008 | 01:16 PM
BlUEMDsrt6's Avatar
Except for intakes and HE, everything else seems to be compatible. Look on www.letmotorsports.com , they have alot of parts for our engines.
Old Jul 17, 2008 | 01:56 PM
SRT6nTulsa's Avatar
The toy made this list: The mechanical stuff should work.
http://www.srtconnection.com/forums/...ead.php?t=3105
Old Jul 17, 2008 | 03:28 PM
Great info tulsa/toy... Shouldnt the CAI's be more or less the same on these two cars? What have you guys found to be the best performing CAI? I'm more or less stock other than a 181mm crank pulley and some phenolic spacers... both from LET. Maybe I should check out your guys classified section. Any modded SRT-6's around Columbus, OH?
Old Jul 17, 2008 | 07:34 PM
tom2112's Avatar
She can ride with me ;)
Wow! You did the pulley before the intake?!? You'll see some serious gains from a good cold air intake. I don't know if it will fit on your SLK, but the NeedsWings CAI is primo for the SRT. Dynos show a 25whp gain from just the NeedWings CAI.
You'll also want to keep your eyes peeled for NeedWings to release their intake plenums. They open another bottleneck in the air intake system on our motors. Check with Rob at NeedsWings to verify that they would fit on your car, but I'd bet they would. His preliminary tests show a 35whp gain from the intake plenums. I wouldn't be surprised if the production version squeaks out a couple more whp.
After that, you may want to look into separating your intercooler coolant from your engine coolant. But I don't have any idea if your SLK is cooled the same as out SRT's. There's a few guys here in the forum with some home built systems.
Also, check with InMotion about getting your ECU tuned. After a pulley, it's a good idea to do a custom tune. They say you can get another 20whp from a good tune - I don't know, as I don't have one yet. But you'll at least see better gas mileage.
Also, I make regular trips to Columbus for work. My next is August 5th. If you'd like to meet up and BS over dinner lemme know.
Old Jul 17, 2008 | 07:47 PM
NeedsWings's Avatar
were just north of detroit if ya want to swing up for some goodies. our CAI will fit (we would need to know its for a slk so we can make the necessary adjustments for you). we have pics of our cai installed on a slk32 i can dig up for you.
Old Jul 17, 2008 | 10:58 PM
ckovach's Avatar
It's nice to see that I'm not the only SLK32 guy lurking around our close cousin SRT6 Crossfires... There's a lot of really great information on this forum and some very helpful people from what I have seen. So here's my first post...
From what I've observed, the SLK32 and SRT Xfires are mechanically virtually identical. What's more interesting is some of the parts seem less expensive on the Xfire. It will be really nice when someone puts together a cross reference of all the interchangeable parts and part numbers. As for mods, I have the Code 3 SC pulley that a number of SRT6 owners are running along with the Code 3 intake mod and a LET Motorsports custum ECU tune. Adding the SC pulley would potentially be too much boost with a 181mm pulley (I am currently running a stock crank pulley), although the Code 3 pulley has reportedly been used successfully with a 178mm pulley and ECU tune and possibly cooler plugs, but also with an upgraded heat exchanger and intercooler pump. The Code 3 intake mod is very simple and is not a cold air intake, but it opens up the plenum and Code 3 claims 13 RWHP increase in conjunction with their pulley boost. I would definitely consider a LET ECU tune among your possible mods and that goes for any car with an E32 motor (i.e., SRT6, SLK32, C32). My butt dyno tells me that the tune doubled the gains from the Code 3 pulley and intake mod...I would say something like 30-40 RWHP. No, I'm not exaggerating; the gain was incredible and the car became an instant animal.
It was mentioned above that the HE isn't interchangeable, but LET represents that their Xfire HE will fit in the '32...I have one coming and we'll see if they're right.
Thanks for posting as an SLK32 owner -- I don't feel quite as lonely out here now... And thanks again to the members of Xfire Forum.
Old Jul 18, 2008 | 12:18 AM
SLK32Germany's Avatar
Thumbs up Re: Compatible Parts SLK32/SRT-6 CF
Hello,
I have the LET HE an Johnson CM30 on my SLK32 for a few months now . It fits with some minor modification on our baby and works very well. Code3 Pulley together with 178mm is much "bigger" than 185mm crank pulley. In my opinion it is too much. A good ECU-tune can be very helpful but keep in mind, that sometimes a tune "feels" 30-40 rwhp and the power gains at the top / under full load aren't that much... Keep up the good work on your car...
Old Jul 18, 2008 | 06:49 AM
How much for the CAI and neccessary parts installed?
Old Jul 18, 2008 | 07:07 AM
tom2112's Avatar
The NeedsWings CAI lists for $450. There's a link in my signature to his website. I would wait for a group buy on it though. I saved a ton that way.
It doesn't come installed, but it only took me about 1/2 an hour to do it myself, and I'm no mechanic. It was easy and the instructions were good. If you can change the oil in a car, or change the brake pads, you can definitely do the CAI install.
Old Jul 18, 2008 | 07:51 AM
Yea I'm sure it wouldn't be an issue but j/w... Is a different splitter needed for this setup? NeedsWings wanna start a group buy??
Old Jul 18, 2008 | 08:26 AM
NeedsWings's Avatar
the grill area is different, shoot me an email sales@needswings.com and we can discuss it and ill send you some pics we have of it installed on the slk32
Old Jul 18, 2008 | 12:16 PM
ckovach's Avatar
Originally Posted by SLK32Germany
Hello,
Hello to the homeland! Glad to hear the the HE will fit. On the tune, LET specifically asked me whether I wanted a "light to light" street tune or a top end track tune, and I was interested in the former. But I understand what you are saying. I will say the the rear end breaks loose more easily and over a wider range after the tune. I'm very happy with it.
On the suspension side, I have been checking around for a shock tower brace similar to the SLK55 Black series, but with little success. I am aware that our cars don't have struts and I know there are mixed opinions about the effectiveness of a brace on our chassis, but a brace certainly won't hurt (hit a hard bump under a high turning load and it will make a difference). Wiechers Sport makes one for the non AMG R170 and one for the SLK55, but none for the '32. They are willing to develop one when they get a '32 in their shop. It would probably fit the SRT6 as well, although CAI conflicts may be an issue depending on what car they use for a test subject. Any interest? Are you anywhere near Nienburg by chance?
Old Jul 18, 2008 | 02:59 PM
NeverEnough's Avatar
It's priceless!!! It doesn't matter, just get one. You have no idea how bottled up your car is without it. If you think it runs good now, just wait. The intake makes almost as much power as the pulley by itself...
Old Jul 27, 2008 | 12:47 PM
NeedsWings's Avatar
thanks for driving up today. it was great to meet ya
Old Jul 27, 2008 | 07:22 PM
Just got my NeedsWings CAI installed earlier today.. Thanks Rob!! It was great to meet you too. I love low speed acceleration hearing the swoosh of that intake breathing.. Ofcourse going fast and hearing it is just as fun .. Thanks again Rob and send me those pics if you don't mind.
Old May 16, 2012 | 07:07 PM
lajv's Avatar
I need to purchase a right rear catalytic converter. Please if anyone can help feel free. My E-mail is lmeaddy@ yahoo.com.( What year slk32amg parts are interchangable w/the srt?)
Old May 16, 2012 | 08:30 PM
cjw's Avatar
cjw
Really old thread revived here, but instead of installing a car why not delete both rear cats, probably cheaper, mine only cost $40, and sounds good imo
