Clunking sound from passenger side at idle?
Old Aug 11, 2008 | 07:22 AM
ohnoesaz's Avatar
Default Clunking sound from passenger side at idle?
Weird... I hear a clunk at idle, from the passenger side of the car. Of course these cars are so short that I can't tell if its in the middle of the passenger side or towards the back... But it sounds a lot like if you lightly let off the brakes, but keep pressing down, you get some creaking as you inch forward. It sounds like one of those creaks, every 5 seconds or so. And the car isn't moving so I don't think its the brakes. I make sure I press down hard to eliminate that as the problem.
Keep in mind I have a bad fuel pump because the car is hard to start after it sits awhile, and I've already checked the relay. I have a fuel pump ordered already. Can a fuel pump clunk/creak?
Thanks!!!!!!!!!!!!!!!!!!!!
Old Aug 11, 2008 | 08:39 AM
cruzinquick's Avatar
Default Re: Clunking sound from passenger side at idle?
It's the brake pads moving. Normal but if it bothers you, change the pads to another brand and should stop the clunk. Could be something else though.
Old Aug 11, 2008 | 08:55 AM
ohnoesaz's Avatar
The car doesn't seem to be moving at all though. I could try putting it in neutrel to see if no power causes the clunk to go away which might point to brakes, the problem is that would also take the tranny out of the equation too. And who knows, what if thats creaking/clunking. Though I doubt it since its definately somewhere on the passenger side. I could be crazy though.
I'll mess with it later.... Any more suggestions are welcome.
Danyuhl
Nov 2, 2019 05:18 PM
PimpDaddy
Sep 29, 2016 11:55 PM
Charles Moore
Aug 1, 2015 02:35 PM
Charles Moore
Aug 1, 2015 02:33 PM
michaelcycle58
Jul 28, 2015 08:12 PM
