Frustrated - Intercooler Pump Failure
Old Oct 23, 2008 | 07:17 PM
svo's Avatar
svo
Default Frustrated - Intercooler Pump Failure
So my car was at the dealership for 6 days - they replaced the coolant temp. sensor but the Supercharger still cuts out after awhile - it takes at least a few minutes of driving hard... I think the mechanics are probably afraid to drive it that hard and for that long. I'm sure they'd crap their pants if they let me drive them to show them the loss of power.
Old Oct 23, 2008 | 07:27 PM
240M3SRT's Avatar
Default Re: Frustrated - Intercooler Pump Failure
Didnt you install the lightning pump or was that someone else...?
Are you sure you bled the bubbles as per woodys method.
Old Oct 24, 2008 | 09:07 PM
pshek's Avatar
Heat problems? I have a new Johnson CM90 intercooler pump for sale. Also got a LET heat exchanger for sale.
FS: LET heat exchanger
FS: Johnson CM90 pump
Old Oct 24, 2008 | 09:18 PM
tighed1's Avatar
I was told by many to just go out and get the Johnson pump, which I did. That alone did not fix my problem. Woody had me move my stock heat exchanger higher up into the air flow and I've been problem free every since.
But that's just my experience.
Old Oct 25, 2008 | 11:40 AM
ohnoesaz's Avatar
Its important to understand most techs at dealerships don't really know what the heat exchanger pump is... Chrysler calls it an auxillary water pump, and mentions nothing about the heat exchanger. The techs are trained to follow written troubleshooting steps and the intake temp sensor is one of the first things to look at. THe reason is because the computer uses that sensor and that sensor alone to determine if the air temps are too hot. Air too hot = bad air sensor according the Chrysler, they don't try to look for the root cause of the hot air.
If I were you I'd be very specific about the auxillary water pump with your dealer, and even pop the grill and show them, and explain that it needs to be running in order to cycle the heat exchanger water through. I know this sounds childish but the srt-6 is an ignored vehicle by chrysler, they have enough mass-produced vehicles for techs to learn.
Also... its my opinion that the pumps fail because the stock heat exchanger is too restrictive. The stress kills the pumps. So upgrade your heat exchanger or branch off a second exchanger in parrellel with the stock one (thanks Woody!) to relieve the work load. etc etc.
Old Oct 27, 2008 | 02:09 PM
Goldwing's Avatar
Just had my car in to the dealer. I wrote up that the intercooler and probably the intercooler temperature sensor had to be replaced and they did both. No problems since.
roar
Jun 15, 2022 11:46 AM
Nexxus
May 8, 2016 04:43 PM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
