Upgraded IC?
Old Oct 31, 2008 | 09:24 AM
  #81 (permalink)
Bulldogger's Avatar
Default Re: Upgraded IC?
Originally Posted by mrphotoman
This is from another forum:
and thanks Razathorn
As one of (if not the, I don't really recall for sure) the first supercharged guys to do water/methanol a few years back, my setup has basically "just worked" for a long while now. Now that I've moved to 11 pounds w/ 06 tsx cam in 100+ degree heat, I find myself needing to make adjustments to keep the detonation fairy and her pings of doom from claiming my 75k oem motor. For a while, off and on, I've dropped little nuggets of explanation in chat threads and random threads -- but I haven't really created a technical resource for those who really want hard info on what is going on behind the scene. This thread aims to fill that void, confuse some of you, and enlighten (hopefully) the rest of you that want to understand things better. If you get confused, ASK questions -- you won't be the only one, and hopefully we can turn this thread into something really useful for others.
First, before we start, we need to get vocabulary out of the way. Without knowing the following terms, you won't get very far here.
-Air/Fuel Ratio
An air/fuel ratio describes how many parts of air and fuel are present during combustion.
-Stoich
Stoich comes from stoichiometry. Stoich, for our purposes, describes the condition where combustion of the air/fuel mixture leaves no remaining oxygen or fuel. I sometimes refer to it as perfect combustion, but don't confuse that with being what you should want at all engine operating conditions.
-Stoich Point
A ratio that defines how many parts fuel to oxygen you need for stoich mixture. The Stoich point of gasoline is 14.7:1, or 14.7 parts oxygen to one part fuel. The stoich point of methanol is 6.4:1.
-Lambda
Loosely defined for our goals, it describes, via a percentage, how much fuel or oxygen was needed for stoich combustion. A lambda value of 1 is stoich. A lambda value of .85 means 85% of your fuel was burned, and 15% of it was left over. A lambda value of 1.15 means 15% of your oxygen was not used, and 85% of it was.
-Lean/Rich
Lean describes a condition when too little fuel is present in your combustion event to be stoich. Rich describes a condition when too much fuel is present in your combustion event to be stoich. A rich mixture has a lambda less than 1.0, a lean mixture has a lambda greater than 1.0. Rich/lean is also used to describe having too much or too little fuel in relation to what is desired, not just in relation to stoich. For instance, even though 14.7:1 is stoich for gasoline combustion, and by definition is not lean, it is far too lean for wide open throttle to be safe, and should be richer.
-Lambda sensor
Your wideband oxygen sensor. It is called a lambda sensor, or air/fuel sensor, because it detects and informs the engine computer the lambda of the combustion event that has just happened -- in other words, how close it was to stoich. Kmanager converts the lambda values to "gasoline air/fuel" ratios for you by multiplying the lambda by the stoich point of gasoline. For example, .85 lambda is .85 * 14.7 = 12.5:1 a/f. The lambda sensor, engine computer, and kmanager are totally unaware of what fuel you are running. If you were to run pure methanol, and tune your car to a perfect stoich air/fuel ratio of 6.4:1, the lambda sensor would see 1.0, and kmanager would report this to you as 14.7:1. It is important that you realize that the air/fuel ratios you know and love are simply a calculation based upon empirical measure that is NOT actually parts of fuel to parts of oxygen. It is also important to realize that when you run a combination of methanol and gasoline, your air/fuel number scale in your head that says "11.5 is safe for boost, 13.2 is not" is still 100% valid and useful -- just think of it as "this is the air/fuel ratio I would be running if I was running purely on gasoline." 11.5:1 gasoline air/fuel ratio literally means 11.5/14.7 = .78 lambda, or 78% fuel was burned, 22% remained unburned (and absorbed heat).
-Methanol
Methanol is a simple alcohol with a stoich point of 6.4:1. It melts/freezes at -98C and has an octane rating of around 120. It has a relatively low flash point, so mixing with water, in addition to adding more cooling benefit to your water/methanol mixture, adds safety by increasing its flash point.
Knock
An engine noise -- not good. Knock generally falls into two categories: spark knock (detonation) and rod knock (or other physical problem with the motor that makes you tear it down).
-Detonation
Detonation is far less harmful than it sounds, but leads to things more dastardly such as pre-ignition or engine damage if left unchecked, especially if the detonation is severe or the engine is already operating near it's physical limits. Detonation is an event that happens AFTER normal ignition of the compressed air/fuel ratio as the cylinder is moving down on the power stroke. Detonation occurs when the air/fuel mixture transitions from burning (granted, very fast) to exploding (hence the word detonation). Ideally, the air/fuel mixture should burn across the time when the piston is moving down on the power stroke. If for some reason the mixture cannot sustain normal combustion under the heat/pressure it is being exposed to, and explodes, this is called detonation. It delivers a large amount of force to the piston very quickly for a very short period of time producing an audible sound referred to as a "ping", and hence "pinging" is another term to describe a motor that is detonating. It heats up the combustion chamber quickly. Normally, when you encounter detonation, it is near the end of the normal combustion event. This is especially true for detonation you encounter from running too much ignition timing -- you can literally think of this as the burn beating the piston. Denser mixtures burn faster -- that's why more boost dictates less ignition timing. Detonation can be caused by too much ignition timing, too little octane, too hot of intake temperatures, or too lean of a mixture.
Highlighted in red my simple point. I know all about it from my moddified diesel truck. My point again is I personally don't see the need for it unless your boost is high enough that you need to cool it or your road racing. You seem to love it so use. I'm sorry, am I not intitled to my opinion if it disagree's with yours?? you should also speak to people in a manner which you would like to be spoken too
Old Oct 31, 2008 | 09:28 AM
  #82 (permalink)
tighed1's Avatar
It keeps going and going an....
Lots of info here. Thanks!
Old Oct 31, 2008 | 09:30 AM
  #83 (permalink)
ACRucrazy's Avatar
So how about them intercoolers.....
Old Oct 31, 2008 | 09:34 AM
  #84 (permalink)
BrianBrave's Avatar
<--- Huge Horsepower
That would be dangerous and could result in detonation and engine damage.
The knock sensors would still protect the engine from detonation....
Old Oct 31, 2008 | 09:40 AM
  #85 (permalink)
ProjectMayhem's Avatar
I hear they transfer the heat from the air into the coolant that flows through them... .
Old Oct 31, 2008 | 09:42 AM
  #86 (permalink)
mrphotoman's Avatar
I would suggest the same to you lol and of course you are entitled to your opinion. Like i said in the other post, that is the fun of modding. Arguing which mods are best and having fun with your car.
Anyway, with the benifits of alky raising octane, preventing detonation and allowing you to safely raise timing and lower intake temps I think it is a great mod. As with any other mod out there you will find pro's and con's and it can cause damage when used to extremes (like raising your boost up to crazy levels or using a 500hp shot of nitrous) but that is the risk you take when modding your car. I always try to do things in moderation to hopefully avoid major expenses.
I am not saying i know a lot about injection but i have read up on it quite a bit and i have used it in the past and I also have chatted quite a bit with a person that is using it on a srt6 and is running great times.
just have fun with your car, that is what matters when it comes down to it.
  #87 (permalink)
MikeR's Avatar
I hear that Code3 has an upgrade available.....
MikeR
Old Oct 31, 2008 | 09:43 AM
  #88 (permalink)
mrphotoman's Avatar
yes it would to a certian extent but that is a dangerous cutting corners mod in my opinion.
Old Oct 31, 2008 | 09:57 AM
  #89 (permalink)
BrianBrave's Avatar
If you wanna boast about your bragging rights on dragtimes.com - you do what ya gotta do!...
Old Oct 31, 2008 | 10:33 AM
  #90 (permalink)
mrphotoman's Avatar
lol that is true!
Old Nov 3, 2008 | 03:14 PM
  #91 (permalink)
c32AMG-DTM's Avatar
Question Re: Upgraded IC?
Anyway, the point is there are many mods out there to chose from. Do the research and pick which one you like best. That is the entire point of modding a car, to have fun with it and experiment with what works best for you. I do stress the research though, there is a lot of misinformation out there.
Like if you have a 1.7% ratio of something in the fuel rail, it somehow dilutes to 0.28% in the cylinder?
Old Nov 3, 2008 | 03:34 PM
  #92 (permalink)
mrphotoman's Avatar
har har har, wow aren't you special! like i said i was doing that off the top of my head, that is hardly misinformation.
So what times are you running with your c32? what is your mod list and plans?
Old Nov 26, 2008 | 06:53 AM
  #93 (permalink)
Mimi05SRT6's Avatar
I dont expect when I ask questions to be given asshat answers from people who think they are above others.
Sounds like MNSC, doesn't it?
Old Nov 26, 2008 | 07:20 AM
  #94 (permalink)
ACRucrazy's Avatar
MikeR
Thats funny, I paid for mine a month ago and it seems to be vaporware.
MMMhmmmm.
Old Nov 26, 2008 | 07:23 AM
  #95 (permalink)
MikeR's Avatar
I saw ONE on a MB SC on the MBworld forum. They are waiting for them over there too. I would like to upgrade mine to that one, but mine still works and dosent leak. I'll wait.
MikeR
Old Nov 26, 2008 | 08:55 AM
  #96 (permalink)
splinter's Avatar
...They are waiting for them over there too...
+1
Originally Posted by Code3 Performance
…This current group buy will end on 10/23. The ICs will be ready to ship by 10/31
photo credit AirFrcd
Old Nov 26, 2008 | 09:48 AM
  #97 (permalink)
SLK32Germany's Avatar
I am waiting for mine, too!
Old Nov 26, 2008 | 11:01 AM
  #98 (permalink)
waldig's Avatar
Talking Re: Upgraded IC?
This is in response to tighed1 on page 1, My error, thought it was from last page, DUGHH: please delete Woody
Old Nov 27, 2008 | 12:12 AM
  #99 (permalink)
240M3SRT's Avatar
Ill admit i havent been following this thread. What kind of dual injection is this supposed to be? Alc, meth, n20, nos?
Originally Posted by splinter
+1
Old Nov 28, 2008 | 10:06 AM
  #100 (permalink)
splinter's Avatar
Sorry, AirFrcd shared no further details with his teaser pic.
deerhunter
Jan 16, 2021 10:56 AM
Sep 28, 2015 07:40 PM
ayebb
Sep 18, 2015 03:35 PM
RacerXofFL
Sep 15, 2015 05:00 PM
darf
Aug 26, 2015 06:41 PM
