Redline
On my way home today i downshifted to 3rd and took off. now i was watching the rpm and it went to 61**rpm's is that normal or does that mean my car may be tuned? from what i have read redline is 5800 or 5900. just curious i tried searching quickly but to no avail.
thanks
thanks
thanks
thanks
Originally Posted by jimmyjet
From whatever you were saying, I gather you experienced "valve float".
God did not intend XF's to be wound beyond 6,000 R's.
Didn't hear any valve float at 7K (which I will add that I never want to do again) when I dropped gears and ended up in 2nd instead of 4th. These cars are very well built engine-wise. Wish I could say the same about the little pesky interior stuff but that's a whole other can of worms.
My tranny has a slow grabbing shift between 3 and 4 so if I floor it I easily go into the 6K+ range during that shift. I usually have to let off the pedal for a second to give the car a chance to shift or else the RPMs will just keep shooting up.
Point being... My srt has no computer tuning and yeah it does it.
Like everyone else has already said. Rendering my response useless.
I almost hate to disagree with members, but being your way off I MUST.
I am not sure how you drive your Crossfire but do you EVER open it up?
The Aluminum and Magnesium block & heads, 12 plugged 18 valved 3.2 Mercedes Benz engine that is in your Crossfire is by no means an engine that would EVER float the valves @ 6000 RPM. I had my 04 Limited past 6 grand often. I have had my Modified SRT Crossfire to 174mph with lots left. Hell I've had it to 150 in 4th gear. If you had ever seen the internals of this engine and seen how much it resembles a tank such a remark would never have been uddered.
You need to get out and push some limits.
Valve floating...
MIke
My car hit 5999.99rpms the other day and I thought I was done for! Talk about a scare!
Some tachs cant keep up with EXACTLY what rpm the engine is at....for that you would need a datalogger of some sort.
The engine might be shifting at 5800-5900 but the response time for the already quickly moving tach needle is too slow and goes to 6100 before falling back. Ive heard of this before.
Originally Posted by svo
NORMAL!! I've gotten mine to shift at 6200 RPM when it was floored and on a slight downhill. The 5800 RPM is when it's on a dyno that doesn't allow the front wheels to spin. YOU"RE FINE!
Benz engine that is in your Crossfire is by no means an engined that would EVER
my Modified SRT Crossfire to 174mph with lots left. If you had ever seen the internals
been uddered.
Valve floating...
MIke
Dear Mikey,
If I would would have only known how offended you would become at my post that indicated
that the gents problem SOUNDED like floating valves, I can assure you that I wouldn't
have even considered "uddering" it.
Concerning your demonstration of driving skill at speeds that would indicate you
might not be too stable, hang in there bud, wind that MB powerplant a little bit
tighter and I'm sure you'll be able hit the magic 200 mark.
By the way, since you seem to use the word "udder" so freely, would that
indicate that you've had carnal knowledge of some of your local Montana cattle
or are you just a milk maid in disguise.
And above all, thanks for all the info on the XF. I'm sure I'll be receiving
more love notes from you quite soon. Love and Kisses, jimmyjet.
been uddered.
Valve floating...
MIke
Dear Mikey,
Aug 4, 2015 04:57 PM
SRT6 Gang Member
Mar 5, 2010 04:18 PM
