My 181 install experience. Boost levels + concerns & thoughts
Old Nov 16, 2008 | 11:44 AM
tighed1's Avatar
Default My 181 install experience. Boost levels + concerns & thoughts
I welcome your comments, suggestions, questions.
Old Nov 16, 2008 | 12:00 PM
ACRucrazy's Avatar
Default Re: My 181 install experience. Boost levels + concerns & thoughts
So 1 psi gain with the code 3? Huh.
Old Nov 16, 2008 | 12:03 PM
Moparrbust's Avatar
Next mod for you...............................Wideband A/F gauge.
Old Nov 16, 2008 | 12:06 PM
Bulldogger's Avatar
Higher elevation probably allows you to get away with both, less air to compress means less heat and less boost. The two combine maybe close to the 185.
Old Nov 16, 2008 | 12:33 PM
Montana Crossfire's Avatar
[QUO That's with no tune and just the mods shown in my signature.[/COLOR][/FONT][/FONT][/COLOR]
Why are you staying away from a tune? The tune is what makes all this extra "work".
You act as though your concerned about issues but the issues wouldn't be realevant if you were to just get the appropriate tuneing on your ECU. I think you would find more zip in your step with just the tune than with just the pulley.
If you are worried,
if you want power,
if you want to experiance the full ability of the gain in boost,
GET YOUR ECU SENT OUT TODAY!
I assure you, you won't be dissatisfied.
PS if you are they will turn it back to stock and refund your money. What have you to lose?
Mike
Old Nov 16, 2008 | 01:06 PM
Squirrel Crusher's Avatar
GOSH! After Tighed1 boost findings,I"m now more interested than ever towards the 185 pulley with cooling mods. Stock idler pulley with a longer belt. And (YES) A tune! I'm still somewhat concerned with the increased waterpump rpm's. Maybe by income tax returns, the magic formular will be discovered. Don
Old Nov 16, 2008 | 01:07 PM
ACRucrazy's Avatar
Someone just needs to make a supercharger replacement.
Old Nov 16, 2008 | 01:15 PM
WHAT????????
Old Nov 16, 2008 | 01:16 PM
ACRucrazy's Avatar
Originally Posted by Montana Crossfire
WHAT????????
INSTEAD OF BOOSTING THE HELL OUT OF THE STOCK SUPERCHARGER SOMEONE NEEDS TO JUST MAKE A BIGGER REPLACEMENT.
Old Nov 16, 2008 | 01:17 PM
You maynot be able to achieve that one without a machinest on hand.
Mike
Old Nov 16, 2008 | 01:18 PM
NeedsWings's Avatar
absolutely, i have seen wideband logs of stacked pulleys (21psi) and they get waaaay ugly lean once the boost builds up, watching the afr curve go from a mid 12 to a jump into the 17afr is crazy and very dangerous to the very expensive amg motor!!!!!!!
i assume were hitting the max of the map sensor causing some of the issues but im checkign into that, either way please get a wideband on the car if you try to install them stacked again but i would absolutely not recommend it yet.
does anyone know the map sensors limitation off the top of their head so i wont have to pressurize one with a volt meter?
Old Nov 16, 2008 | 01:20 PM
robby363's Avatar
Originally Posted by tighed1
My tail pipe tips are constantly black.
They get like that on a stock SRT-6 also.
Old Nov 16, 2008 | 01:23 PM
To the bigger replacement comment..
Never mind, Shiiiii!
Old Nov 16, 2008 | 01:24 PM
ACRucrazy's Avatar
Yep, Ive noticed that with mine, I assumed its the stock computer is running rich to keep things cool and safe.
Old Nov 16, 2008 | 01:26 PM
ACRucrazy's Avatar
This whole 10 character minimum is annoying.
Old Nov 16, 2008 | 01:27 PM
BLKFIN's Avatar
ADDICTED TO BOOST
I would think you have a boost leak somewhere. I saw 19lbs of boost yesterday at the track with just my Code 3 and on the street I see 17-18. Also, where is your boost gauge tapped?
Old Nov 16, 2008 | 02:21 PM
tighed1's Avatar
[QUO That's with no tune and just the mods shown in my signature.[/color][/font][/font][/color]
Question: Why?
Answer: $$$$$
When I get the "extra" money to get a tune I'll get one.
Will also have to do research to see which tune gives the best results as report by my friends here on CrossfireForum.org!
Donations towards tune accepted!!
Old Nov 16, 2008 | 02:24 PM
tighed1's Avatar
I believe that the 4000 ft difference in elevation may be the difference in boost, not a leak.
Boost is tapped at the "Y" that comes out of the IC. Have seen a lot of us have used the same spot.
Old Nov 16, 2008 | 03:04 PM
BLKFIN's Avatar
ADDICTED TO BOOST
I installed mine at the Y as well and that was the issue. I had a loose worm clamp that was leaking boost. My gauge was reading 13-14 with the Code 3 as well, then I went back over all the possible connections and found the issue. It looked perfect, but is was just not seated correctly. Now I see the 17-18 on the street all the time. The oil blow thru makes it very easy to get a leak. Just my experience....Good Luck!
Old Nov 16, 2008 | 03:26 PM
spoke to you last week and thought u had a tune ,,as i had told you i am running out of fuel with my tune , you being stock ecu you may have all the fuel you need but the only way to really know is dyno or air fuel gauge,, will do mine next week or so and let u know what i find. jim
