SRT DOWN! Post your Out Of Order troubles here.
Old Jan 10, 2009 | 10:31 PM
tighed1's Avatar
Angry SRT DOWN! Post your Out Of Order troubles here.
STATUS:
REASON DOWN:
SYMPTOMS:
TROUBLESHOOTING PROCEDURE:
SOLUTION:
Old Jan 10, 2009 | 10:37 PM
tighed1's Avatar
Default Re: SRT DOWN! Post your Out Of Order troubles here.
STATUS: Open
REASON DOWN:
My SRT is currently down because of an issue with the serpentine belt being cut .
SYMPTOMS:
Belt travels back one rib on the crankshaft pulley causing the pulley edge to cut off one rib of the belt off.
SOLUTION:
Old Jan 10, 2009 | 10:54 PM
tighed1's Avatar
OK SRT folks I thought that I'd try a thread where we can post troubles that DEADLINE our cars. Might be helpful to someone along the way to document these problems.
The initial post is the template. Copy it, paste it, and fill in the blanks thus-ly.
STATUS: Enter current status of your trouble. 'Open' or 'Closed'.
REASON DOWN: Describe the problem that has caused your car to be un-drivable.
SYMPTOMS: List symptoms of the problem. Overheating, won't start, loss of boost, bearing seized etc.
TROUBLESHOOTING PROCEDURE: Steps you have taken to isolate/identify the cause of the problem.
SOLUTION: What was ultimately done to correct the problem.
Old Jan 10, 2009 | 11:12 PM
Originally Posted by tighed1
STATUS: Total non function
REASON DOWN: Funding shortfall
SYMPTOMS: Empty space in my garage, A whole lot of empty.
TROUBLESHOOTING PROCEDURE: Searching Ebay, Auto trader
SOLUTION: Purchase Lotto, put firstborn up on Ebay, Saturday mornings I stand at the entrance ramp of I70 with a sign, "Will work for SRT"
Sorry Tighed1. I know your thread is serious but I couldn't help it.
roadster with a stick
Old Jan 10, 2009 | 11:18 PM
SRT6nTulsa's Avatar
Nice one, Franc.
Good luck with your pursuit. This spring, I hope to be trying to catch you at the dragon.
(This is probably already the case on the twisties. My SRT only helped me on the sweepers.)
Old Jan 10, 2009 | 11:22 PM
Originally Posted by SRT6nTulsa
Nice one, Franc.
That's three on my ****. oledoc2u, Jane Bridges, and now the fastedt SRT in Oklahoma!
I'm honored.
And.....you're on pal
Old Jan 11, 2009 | 06:57 AM
H.K. Phooey's Avatar
STATUS:
Still rattles and I'm going back to the dealer next week.
REASON DOWN:
Rear struts blown
SYMPTOMS:
Loud rattles from the rear.
Dealership tried a repair kit and ended up ordering new ones, it took 20 days and I heard ever excuse. My service rep is great but the rest of them, not so much.
SOLUTION:
New Struts, they broke my key as well.
Old Jan 11, 2009 | 07:39 AM
Kurts's Avatar
STATUS:
Completely drivable!
REASON DOWN:
Not so much down as not 100% happy.
SYMPTOMS:
Squeaks & groans from rear wheels. Occasional oil-like droppings on driveway.
Listen for squeaks from rear wheels when braking. Stare & grumble at oil-like droppings.
SOLUTION:
Replace rear brake rotors, check pads. Take car to dealer & have them check for infamous tranny leak.
I actually had the SRT out of the garage for the 2nd time since the beginning of Dec. yesterday.
Had to burn through some gift cards from Best Buy & Barnes & Noble.
Decent day, temps. in the upper teens, sunny & dry & the roads haven't been this good since I can't remember when. Perfect day to get it washed, too!
Old Jan 11, 2009 | 08:36 AM
SRT-6 Steve's Avatar
STATUS: No issues since purchasing in Sept. 2007 other than headlight replacement 26,000 miles on the odo.
REASON DOWN: Oxidated / Moisture
SYMPTOMS: Looked light ****
TROUBLESHOOTING PROCEDURE: Dealer replacement under warrant.
SOLUTION: They scratched the pee out of the front bumper cover just under the light [/quote]
Old Jan 11, 2009 | 11:37 AM
Andy G's Avatar
STATUS: Closed (13k Miles)
REASON DOWN: Fluid Leak
SYMPTOMS: Oil leak spotting on driveway
TROUBLESHOOTING PROCEDURE: Checked out as oil sump leak from drain plug.
SOLUTION: Drain plug wouldn't tighten as backing flange had come lose. New sump required. Covered under warranty. Off road 3 days
Today 12:39 PM
Old Jan 11, 2009 | 11:40 AM
Andy G's Avatar
STATUS: Closed 13K miles
REASON DOWN: Alternator failure
SYMPTOMS: Battery warning light coming on above 3500 RPM
TROUBLESHOOTING PROCEDURE: Dealer check
SOLUTION: Replaced alternator under warranty. Off road 4 days
Old Jan 11, 2009 | 11:43 AM
Andy G's Avatar
STATUS: Open 15k miles
REASON DOWN: Driveable but water pump failure imminent
SYMPTOMS: Bearing rattle at water pump housing
TROUBLESHOOTING PROCEDURE: Checked by Dealer when in for Alternator replacement, at my request
SOLUTION: Dealer awaiting replacement water pump. On back order with MB; has been for over two months.
Old Jan 17, 2009 | 06:59 PM
Coyote's Avatar
STATUS: Resolved
REASON DOWN: Idler pulley failing.
SYMPTOMS: ringing, screeching noise.
SOLUTION: Replaced idler pulley under warranty. Off road 11 days
Old Jan 17, 2009 | 09:04 PM
tighed1's Avatar
STATUS: Closed
Old Jan 17, 2009 | 09:48 PM
ProjectMayhem's Avatar
STATUS: Closed (5K)
REASON DOWN: Alternator Failure
SYMPTOMS: Battery light on dash, then car would not go above 1,500 rpms
TROUBLESHOOTING PROCEDURE: Tested battery, battery was within specs. figured it was alternator
SOLUTION: Dealer replaced alterntor issuse solved! took 9 days!
Old Jan 18, 2009 | 04:44 PM
SATUS RESOVED.
Areo Blue SRT; In the driveway.
"Check out pictures in the one that got away" in about an hour.
tom2112
Jul 28, 2015 08:12 AM
leaddog2015
Jul 13, 2015 12:25 PM
SRT SIX
Jun 22, 2015 05:37 PM
WindRestrictor
Jun 16, 2015 12:18 PM
chuckhaze
Sep 5, 2003 12:40 AM
