Trouble Starting
Old Jan 16, 2009 | 05:49 PM
jimpn's Avatar
Post Trouble Starting
I took my 05 SRT6 to car wash and was approached by vallet "that my car would not start" I went to investigate and sure enough turn the ignition power was available but no ignition. We let the car sit for 30 minutes and tried again with no avail. Unhooked power cables, reconnected with no luck. Just seeing if anybody has had the same trouble?
Old Jan 16, 2009 | 05:56 PM
crossfirefun's Avatar
Default Re: Trouble Starting
If the lights light and there is plenty of juice in the battery but it doesnt turn over then you more than likely need a new board under the hood. do a search for mystery no start. Listed in that thread are the symptoms and remedy.
Old Jan 16, 2009 | 06:06 PM
jimpn's Avatar
Thanks for the info.
Old Jan 16, 2009 | 07:53 PM
apkano's Avatar
Life is random...so am I.
You let a valet drive your SRT???!!!?!?!?!?!??! You are hereby obligated to hang your head in shame!
In all honesty....I agree with crossfirefun.....it could very well be the relay control module.
https://www.crossfireforum.org/forum...ignition+relay
Old Jan 16, 2009 | 08:15 PM
Kurts's Avatar
Silly question on my part but:
I had the exact same thing happen in a car wash. I was a newbie & didn't know that if the car was in the Acces. position & then turned to "Start" it won't start!
The ignition key has to be turned all the way off.
And then on again.
I'm assuming you did this?
KDW4Him
18
Sep 1, 2021 05:47 PM
minimayhem
16
Aug 23, 2016 07:47 AM
RojoGTO
Feb 6, 2016 11:14 AM
Firebombbandit
Sep 3, 2015 06:42 PM
TOPLA
Jul 14, 2015 07:46 AM
