Got Code3
Old Mar 20, 2009 | 08:17 PM
velociabstract's Avatar
Default Re: Got Code3
I have a dial caliper but little expertise in measuring. But I got 2.9" on the stock pulley and 2.57" on the aluminum pulley. So if you have the new mid sized you should be somewhere between the two. Brandon answered my email a while ago so if you sent him one, he's most likely working through them now. Here's hoping you got what you wanted.
Les
Old Mar 23, 2009 | 05:01 PM
PA/XFIRE's Avatar
USED A CALIPER AT NAPA, MY CODE 3 S/C PULLEY IS A MIDSIZE 2.7" =68.58 MM SHOULD HAVE LOOKED FOR A CALIPER FIRST. THE OEM S/C PULLEY IS 2.9" =73.66 MM. THE ORIGINAL CODE 3 S/C PULLEY IS 2.57" = 65.27 MM ALL INFO IN INCHES PER BRANDON. ILLCYA
Old Mar 23, 2009 | 05:12 PM
Thanks PA / XFIRE, it looks my measuring is getting better. I was real close. It may be a week or two before I can instal my Code3. I have what appears to be a transmission fluid leak and I over cooked my brakes on Sunday at the track. So dealer first and pulley afterwards. I prefer they don't notice the brakes as I have brake parts ordered already.
Les
Old Mar 23, 2009 | 05:43 PM
tom2112's Avatar
She can ride with me ;)
Les, don't forget there's a service bulletin about the tranny leak. It is likely the seal around a wired connector.
It's SB_21_002_05_Transmission_Leak.pdf in the TSB file listed in the first post of this thread:
https://www.crossfireforum.org/forum...ad.php?t=13875
Old Mar 23, 2009 | 06:03 PM
Thanks for the info. I already have it downloaded and printed should the dealer become obstinate. I will try to get under the car before taking it in. If its something I can do myself, nah, its the dealers responsibility.
Les
tom2112
Jul 5, 2015 09:20 PM
rcompart
41
Feb 1, 2011 07:35 AM
billvp
Nov 25, 2010 05:44 PM
Airfrcd
May 8, 2009 06:11 AM
Thumper SRT6
Jan 28, 2009 05:45 PM
