Just another cracked pump picture thread
Old Apr 1, 2009 | 12:08 PM
XXxx_Totmacher_xxXX's Avatar
Talking Just another cracked pump picture thread
I'm sure there are alot on here. Replaced the pump on our Crossfire. Had 17k when we got it and it was obvious the pump was gone. These pumps are rated by hours, not miles so i would assume the car was driven in heavy stop and go traffic before us (more hours run per mile driven). Also excessive engine startup/shutdowns would contribute as i believe the pump runs for a bit when the car is turned off.
Anyway on to the carnage...
Old Apr 1, 2009 | 12:20 PM
///SilverSaphRT6's Avatar
Default Re: Just another cracked pump picture thread
Is it hard to replace?....I might as well get the Johnson pump and get it out the way.
Old Apr 1, 2009 | 12:23 PM
15 minutes, floor jack, torx bit, soldering gun, lighter, snips, 8mm & 10mm socket, and one or 2 beers, it may be a 3 beer job if it's a sunday morning.
Old Apr 1, 2009 | 12:27 PM
dead giveaway the pump took a **** is the car disengaging and reengaging the supercharger. you can feel it just cruising. car stumbles for a split second and the rpm's bounce a bit
Old Apr 1, 2009 | 01:52 PM
waldig's Avatar
Talking Re: Just another cracked pump picture thread
If your pump is still working and you choose to replace it, SAVE it. It is the same pump that you use to heat the cabin of the car. Mounted under passenger head light. Ta DAAA
Woody
Old Apr 1, 2009 | 01:58 PM
mrphotoman's Avatar
mine looked just like that and lasted a whopping 1000 miles on the car lol.
Old Apr 1, 2009 | 02:46 PM
So who's going to be the first to put a CM-30 in there heater core loop?
Old Apr 1, 2009 | 03:18 PM
SRTpowa's Avatar
I have a Cm30 in my trunk. Does that count for something.
Old Apr 1, 2009 | 04:20 PM
cross><hair's Avatar
Mine worked fine (12k miles) but I decided to preemptively replace it. Less hastle later on.
Oh and Woody- I DID hang on to it- just in case. Very cool info about it being the same as the heater pump. I hang on to all my old parts (stock intake, stock brake pads, etc).
Old Apr 1, 2009 | 06:56 PM
007_MI6's Avatar
I guess I need to do mine. I have that stumble when I am cruising, usually around 60-70mph. Feels like more of a surge than a hiccup, but still out of place. Thanks for the thread, I guess I will give it a shot since I have the stumble and 30K miles. :P
Old Apr 1, 2009 | 09:30 PM
BLKFIN's Avatar
ADDICTED TO BOOST
That is the same thing I did, I wanted to change it when I felt like it....not the car~
Old Apr 1, 2009 | 09:34 PM
Woody, does the Limited Version use that pump for cabin heat? or just the SRT? James
Woody
Old Apr 1, 2009 | 10:05 PM
NeverEnough's Avatar
The Limited uses the same pump for the REST Cabin Heat Function.
It also works great to cool the car down FAST at the track!!!
waldig
Jul 31, 2017 09:46 AM
Soma
Dec 14, 2015 07:52 PM
Steven 4190
Aug 15, 2015 10:35 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
